What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.19.2008, 07:53 PM
Lookin' good!
rchippie
rchippie's Avatar
10.19.2008, 07:57 PM
Thank you
Does anyone know if they make a plastic spur to replace the steel one on GTP ?.
REAL MEN RUN BRUSHLESS
10.19.2008, 08:31 PM
Originally Posted by rchippie View Post
Thank you
If it is the single speed, the ofna 51t plastic spur bolts right on.
rchippie
rchippie's Avatar
10.19.2008, 08:54 PM
Yes it is a single speed james . Thats great news . I was going to ask if this could be moddedd to fit ? .
http://www3.towerhobbies.com/cgi-bin...?&I=LXHSY8&P=7
10.19.2008, 09:23 PM
ofna do one to I think it is for the pirate - I can check when I get back on ties
What's_nitro?
10.20.2008, 03:16 AM
Probably. You could use the steel spur as a template for the four holes.
10.20.2008, 09:06 AM
Do they make a plastic spur for the hyper ST centre differential?
10.20.2008, 09:27 AM
If it is the std plastic case non-spider design, a kyosho plastic spur will work. They only come in 44 and 46t though, but should work since the st has 11/43 diff ratio.
10.20.2008, 09:29 AM
Here is a link to the gear that will fit the gtp: http://www3.towerhobbies.com/cgi-bin...?&I=LXBM16&P=7
rchippie
rchippie's Avatar
10.20.2008, 10:51 AM
James that gear would be the easyest to use since there would be no modding needed . I was just trying to use the stock ratio if possible .
10.20.2008, 10:54 AM
That is the gear I use on my gtp with the kb45 motor. I have not had any issues with it so far. I do not like steel spurs due to the noise, and the only 6mm bore pinions I found were not hardened, so I had to use a plastic spur.
rchippie
rchippie's Avatar
10.20.2008, 10:58 AM
Thats the reason i want to use the plastic spur because of the noise .
10.20.2008, 11:08 AM
That is the main reason I use them. And hopefully it is slightly weaker than the glue used to hold the magnet on the motor shaft. I would rather replace the spur than the motor.
10.20.2008, 12:41 PM
Just put a stereo on your vehicle. And yes, it's possible (I've done it).
10.20.2008, 01:01 PM
I had not seen that before, thanks for the laugh!
