rchippie
rchippie's Avatar
10.19.2008, 07:57 PM
Thank you
Does anyone know if they make a plastic spur to replace the steel one on GTP ?.
REAL MEN RUN BRUSHLESS
10.19.2008, 08:31 PM
Originally Posted by rchippie View Post
Thank you
If it is the single speed, the ofna 51t plastic spur bolts right on.
rchippie
rchippie's Avatar
10.19.2008, 08:54 PM
Yes it is a single speed james . Thats great news . I was going to ask if this could be moddedd to fit ? .
http://www3.towerhobbies.com/cgi-bin...?&I=LXHSY8&P=7
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.20.2008, 03:16 AM
Probably. You could use the steel spur as a template for the four holes.
10.20.2008, 09:06 AM
Do they make a plastic spur for the hyper ST centre differential?
10.20.2008, 09:27 AM
If it is the std plastic case non-spider design, a kyosho plastic spur will work. They only come in 44 and 46t though, but should work since the st has 11/43 diff ratio.
10.20.2008, 09:29 AM
Here is a link to the gear that will fit the gtp: http://www3.towerhobbies.com/cgi-bin...?&I=LXBM16&P=7
