mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
11.10.2008, 04:42 PM
Put a male end on the MMM then use http://www.maxamps.com/Deans-Series-Adapter.htm this for a series connection and http://www.maxamps.com/Deans-Parallel-Adapter.htm this for a parrallel connection. Of course you can make your own with whatever connector you want. I prefer Traxxas connectors myself, MaxAmps only sells a series connector with Traxxas ends, but you can make your own parrallel one.
wow! thanx. i would never have thought of that! in will use the traxxas connectors and feamle on batts to prevent shorts. im goin to make my own harness's . tahnx for the idea
edit: new diagram
-mikey09120
stum
11.10.2008, 07:37 PM
This may help some peope understand...
11.10.2008, 08:09 PM
A series harness, with a parallel adaptor on one side, and a jumper on the other. How very multi-functional
mikey09120
mikey09120's Avatar
11.10.2008, 09:04 PM
wow guys! this is all assuming that it will come with batt wires soldered to the board. if they are bullets than it is apiece of cake. i need to order a couple ounces of common sense. im glad it got simpler
-mikey09120
mikey09120
mikey09120's Avatar
11.10.2008, 09:40 PM
and here it is
-mikey09120
mikey09120
mikey09120's Avatar
12.02.2008, 11:58 PM
couple more questions...
as you know. i have been thinking of buying the slayer parts necessary to convert my e-revo to an e-slayer when i want to.
i will need
arms
driveshafts
push rods
turnbuckles
axle carriers
tires/wheels
now here is where i am stuck
wheels:
-EPIC
-SC8
tires:
-flat iron
-switch
bodies:
-traxxas
-hardcorr
-desert rat
-SC8
head spinning!!
ive heard traxxas "beadlocks" are fake and the tires suck
-mikey09120
Carraig042
12.03.2008, 12:14 AM
Bleh.... Never mind
-Brett
mikey09120
mikey09120's Avatar
12.22.2008, 11:26 PM
another update:
im gonna use switch tires on epic beadlocks with an SC8 body.
due to the economy i will only buy one pair of lipos
2x zippy 3s 5000maH 20C-30C
with a hyperion duo charger.
i have a BLE e-revo on order and sold my stock e-revo to a friend
-mikey09120
himalaya
himalaya's Avatar
12.23.2008, 12:25 AM
I would suggest a Futaba servo, say BLS351, because it's a direct fit to the servo horn comes with the stock E-Revo. The TRX horns are nicely designed having double(upper and lower) arms to lock the ball in middle. Other servos may require changing the horn which is a pitty.
....What a Blue Sky....
mikey09120
mikey09120's Avatar
12.23.2008, 04:37 PM
what is the torque, speed, and color of the servo? price?
-mikey09120
12.24.2008, 09:30 AM
Shaz-zam (google is your friend):
http://www.espritmodel.com/browsepro...ba-BLS351.HTML
Servo Futaba BLS351
Manufacturer Futaba
Applications Heli/Airplanes
Type Brushless High Torque
Torque 4.8V 168 oz/in (12 kg/cm)
Torque 6.0V 210 oz/in (15 kg/cm)
Speed 4.8V 0.16 sec/60 degrees
Speed 6.0V 0.13 sec/60 degrees
Dimensions 41mm x 38mm x 20mm
Weight 62g
Bearings Dual Ball Bearing
Gear Type Metal
mikey09120
mikey09120's Avatar
12.24.2008, 01:47 PM
$140?!
wow... with less torque than stock but a really good speed. ill stick with the 5955TG. i hope there are still some on ebay
-mikey09120
12.24.2008, 02:04 PM
Ebay is always your friend- I've contemplated one of the Hitec 5955tgs myself, but Im too tight and lazy, so I'll just live with my old faithful pair of 645mgs for steering duty.
mikey09120
mikey09120's Avatar
12.29.2008, 10:22 PM
update:
ERBE on pre-order
sold my stock e-revo to a freind.
wheelie bar traxxas 14.99
sway bar kit tekno 21.99
VDP traxxas 4.99
wheelie bar wheels traxxas 16.99
HD servo saver spring traxxas 2.99
aluminum servo arm proline 10.99
7950TG HiTec 134.99
clear body(e-revo) traxxas 17.99
extended axle carriers qoncepts 55.95
extended track kit kershaw 29.99
extended arms traxxas 11.99
nyloc nuts 17mm (8) team associated 12.99
traxxas 17mm traxxas 19.99
slayer arms traxxas 22.99
slayer driveshafts traxxas 18.99
slayer pushrods traxxas
slayer turnbuckles traxxas 6.99
axle carriers traxxas 16.99
SC8 wheels and tires black assembled (4)
team associated 75.99
slayer bumpers traxxas 11.99
SC8 body team associated 39.99
black beadlock screws team associated 12.99
also with zippy 3s 5000maH 20C batts and a hyperion 0610I Duo with an ofna 12V 10A PS
-mikey09120
mikey09120
mikey09120's Avatar
03.28.2009, 02:26 PM
been a long time... but i got my ERBE!!
and i have 4x zippy 3s 5000mah 30C, GTA-6-10 charger, and a 16v 14a PS on order from hobbycity
-mikey09120
