Put a male end on the MMM then use http://www.maxamps.com/Deans-Series-Adapter.htm this for a series connection and http://www.maxamps.com/Deans-Parallel-Adapter.htm this for a parrallel connection. Of course you can make your own with whatever connector you want. I prefer Traxxas connectors myself, MaxAmps only sells a series connector with Traxxas ends, but you can make your own parrallel one.
wow! thanx. i would never have thought of that! in will use the traxxas connectors and feamle on batts to prevent shorts. im goin to make my own harness's . tahnx for the idea
edit: new diagram
-mikey09120
wow guys! this is all assuming that it will come with batt wires soldered to the board. if they are bullets than it is apiece of cake. i need to order a couple ounces of common sense. im glad it got simpler
couple more questions...
as you know. i have been thinking of buying the slayer parts necessary to convert my e-revo to an e-slayer when i want to.
i will need
arms
driveshafts
push rods
turnbuckles
axle carriers
tires/wheels
now here is where i am stuck
wheels:
-EPIC
-SC8
tires:
-flat iron
-switch
bodies:
-traxxas
-hardcorr
-desert rat
-SC8
head spinning!!
ive heard traxxas "beadlocks" are fake and the tires suck
-mikey09120
another update:
im gonna use switch tires on epic beadlocks with an SC8 body.
due to the economy i will only buy one pair of lipos
2x zippy 3s 5000maH 20C-30C
with a hyperion duo charger.
i have a BLE e-revo on order and sold my stock e-revo to a friend
I would suggest a Futaba servo, say BLS351, because it's a direct fit to the servo horn comes with the stock E-Revo. The TRX horns are nicely designed having double(upper and lower) arms to lock the ball in middle. Other servos may require changing the horn which is a pitty.
what is the torque, speed, and color of the servo? price?
Ebay is always your friend- I've contemplated one of the Hitec 5955tgs myself, but Im too tight and lazy, so I'll just live with my old faithful pair of 645mgs for steering duty.
