Taping tires am I doing it right? Pics
Revo_Troop
Military Muscle
Revo_Troop's Avatar
Taping tires am I doing it right? Pics - 03.09.2009, 12:03 PM
Here some pics took 1 inch 100mph tape ran one strip and the last pic shows the overlap amount am I on the right track?:Cheers:
  Send a message via Yahoo to Revo_Troop
03.09.2009, 12:14 PM
That is how I do it. Works fine, and your overlap looks to be about 1" or slightly more. As long as the tire is clean the tape will stick well.
Revo_Troop
Military Muscle
Revo_Troop's Avatar
03.09.2009, 12:26 PM
any tricks on getting the rim to slide better that wont conflict with the glue?...lol
skellyo
skellyo's Avatar
03.09.2009, 12:31 PM
What do you mean "rim to slide better"?
Revo_Troop
Military Muscle
Revo_Troop's Avatar
03.09.2009, 12:33 PM
to slide into the tire it sorta starts sticking part way
skellyo
skellyo's Avatar
03.09.2009, 12:41 PM
You have to stretch the tire a bit to get it over the beads. Also be sure that the foam isn't wadding up.
Another trick before gluing the tires...
Scuff the bead of the wheels and tires with some scotchbrite and clean the surfaces with some alcohol to remove any residue. This will help immensely in getting the tire adhered to the wheel.
Revo_Troop
Military Muscle
Revo_Troop's Avatar
03.09.2009, 01:09 PM
thanks for that!
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.09.2009, 03:31 PM
I have do the same with you and I'm not happy with the result. so now I let my tire balooning again and I can handle it better than taped tire :) I'm talking here on monster tire size.
on the other way with 1/10 tire I love the result with my rustler :)
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
thanks
obelix
thanks - 03.09.2009, 03:48 PM
Thanks I did not know this.What type of tape is best to use.
HPI BAJA 5B SS
HPI HELLFIRE SS
KYOSHA INFERNO SP VXL
RUSTLER VXL
BANDIT VXL
Revo_Troop
Military Muscle
Revo_Troop's Avatar
03.10.2009, 01:40 AM
I used 100mph tape...stuff I had available think as far as tape goes its pretty good.. here is the finished product...still need to seat teh bead a little better then apply the glue and ensure the bead it set right...but they are on the rim...
dmeylman
03.12.2009, 10:58 PM
Off topic...but I have a question about badland tires. Looking on top, Is the other side of the tire suppose to be a little flat than the other? And also, I have maximizer beadlock 0 offset, do I need to use shim on both sides? The manual states that if using proline tires...thanks...
rhylsadar
rhylsadar's Avatar
03.13.2009, 04:06 AM
hi
i did it exactly the same way.
however my longterm experience is not that good with taped tires. once some water or dirt gets into the tires (which is impossible to avoid imo) the tape can get loose and then things mess up rather quickly.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
Finnster
KillaHurtz
Finnster's Avatar
03.13.2009, 04:02 PM
I used reinforced packing tape once to tape the tires, and my results were the same as above. Ballooned less, but still did some, tape came loose after a while and I eventually just had a wad of tape whirling around in the wheel. I had beadlocks and took it off and it was a mess. I just said screw it until I see something that works better. G/L w/ this tape.
azjc
03.13.2009, 07:47 PM
I have gotten good results running a low profile truggy tire the shorter side wall cuts down on the balloon effect
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
03.15.2009, 02:02 AM
what a coincidence that this showed up in the general discussion recently! from what ive read the kevlar works extremley well with preventing ballooning
http://rc-monster.com/forum/showthread.php?t=19426
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
