CVDS for Flux?? Which ones?? -
03.17.2009, 05:49 AM
I was looking at the factory hpi cvds are these any good and they will work with the flux right?
03.17.2009, 08:24 AM
I don't think you'll find any CVD's as beefy as the stock dogbones. Any reason why you don't like the dogbones?
WARNING: May become violent.
03.17.2009, 01:04 PM
Try to find some hardened universals. CVD's arent reliable with heavy torque.
RIP- Tammy (9/14/08)
03.17.2009, 03:34 PM
No reason I just broke my a arm and the dogbone flew out and could not find it, i was just looking for an excuse to get cvds but if there not strong enough I will stick with dogbones
03.17.2009, 04:17 PM
You should be able to find some of the dogbones pretty cheap on eBay. There are a lot of folks parting them out right now. I won an auction last night for $7.05 for all 4 corner dogbones and the 2 center dogbones.
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110362008822
03.17.2009, 04:52 PM
There's a pic somewhere in these Savage forums of a sheared universal... I haven't broken one of the Savage CVDs (made by HPI) from too much torque. It only broke because of a hard crash.
Personally I would recommend the HPI CVDs, but my Savage has a center diff which takes a lot of stress off the drivetrain. Thus I have no idea how well they would hold up to the Flux.
KillaHurtz
03.18.2009, 02:23 PM
You will have to get the smaller diff cups to use the HPI cvds. The flux has the upgraded dogbone like on the XL. I personally wouldn't bother yet, get a spare set (get some spare hinge pins too, trust me.) You would have a # of spares, and if you find you are losing them frequently still, then I would think about changing.
All those parts are cheap on the bay.
03.18.2009, 02:33 PM
Ah, good point about the cup size. I came from the Savage X/25 side.
03.18.2009, 03:02 PM
I shredded a ton of cvd pins and most people say that hardened universals are alot more reliable. I tried a set on my e-maxx and on my custom Schumacher MI2 4wd buggy and never had problems after switching.
03.18.2009, 09:36 PM
Universals generally are stronger since they use larger pins, but the first problem here is finding ones that are hard enough, and are made for the Savage XL/Flux.
Originally Posted by traxxasbasher13
Those will have the same issue with the Flux as the HPI CVDs mentioned above. The output cup accepts a larger ball end, so any CVDs made for the Savage 21/25/x/4.6 will have a lot of slop in the receiving end.
03.19.2009, 12:46 AM
wait, so i have to get larger diff cups if i wanted to use the flux dogbones with my savage x 4.6 brushless conversion?
03.19.2009, 02:46 AM
I tried the HPI Universals, and went back to the stock flux dog bones within a day. The heavyduty stuff that's on there already is the best you'll find right now
06.07.2009, 10:20 PM
Definitely don't use CVDs, they will bend on hard jumps and cartwheels. I went through a few pairs on my brushless Revo before realizing you need the give... Dogbones is the way to stay.
06.28.2009, 10:28 PM
I found out that I cracked the stock wheel hub side cup (hope I said that correctly) on my front wheel this weekend. The steering was all bound up - couldn't figure it out until I just about has the whole front end tore apart.
That's a heck of a thick piece of steel to crack, but someway, somehow, I did it!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
