Finnster
KillaHurtz
Finnster's Avatar
03.23.2009, 09:57 PM
Originally Posted by Raze ST Truggy View Post
I have both the CC2200 and a 80mm 1600kv Medusa and an MMM for both. I was thinking that the medusa was better suited for the muggy, but after reading this thread I'm not sure.
What do you guy's think is a better combo for a muggy, and since I'm asking which for my Raze ST Truggy? Thanks
Sorry if this is a hyjack.
-Brian
Run them both and lets see a side by side!
Raze ST Truggy
03.23.2009, 10:03 PM
An eagle tree setup is my next order, but I can't pull that trigger just yet. Once I get that I'll post up all kings of results. I've got a bunch of stuff I want to get data from.
-Brian
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.23.2009, 11:03 PM
Originally Posted by Aceldama View Post
I don't own any 1/8 scale motors yet BUT I feel the same way you do.
On paper 2200kv is too much, especially since I plan on running 6s. If CC/Neu offered a 1600kv or thereabouts then I think it'd be a stronger argument. But as it stands, on paper, the 1600kv Medusa seems like a much better fit for 6s.
I tried running my 1515 2.5D on 6s and quickly switched to 5s! On 6s even at 3/4 throttle I still couldn't give it everything cause it's flip over backwards! 5s is much more driveable IMO for this motor. I'm planning on running the 36-70-1600, MMM, 23t pinion and I have 54,56,58,62,65,+68t spurs to get the speed for a particular track or bashing. I also have a 20t and 25t pinions already.
jsr
03.23.2009, 11:22 PM
Whichever one generates more torque is what I'd run in the Muggy as it's a heavier truck.
Originally Posted by stum
PS check the specs, the medusa 80mm will run hotter than the castle-neu, it cannot generate anywhere near as much torque.
stum - what specs are these? Sorry, I don't know how to read the specs for motors or even where ther are.
GO-RIDE.com
03.24.2009, 12:26 AM
I've driven 3 different E-8ight buggies with MMM, 4S, and the following motors: Medusa 60x2000, Castle Neu 2200, Neu 1512 2050
Castle Neu: I didn't really like the Castle Neu. It was jerky in acceleration, very jerky on the brakes, and had the most drag by far when turning off power
Neu 1512 2050kv: This is a very easy to drive motor with plenty of power, but still very smooth and controlled for a non-sensored motor. It had the least amount of off power drag and allowed the buggy to turn better than the others.
Medusa 60x2000 (I own this one): Sits between the two motors in smoothness and ease of driving. IMO much better than the Castle Neu, but the Neu Neu was also a lot better than the Medusa.
Seeing as the Castle Neu 2200 is more comparable to a Neu 1515 or a Medusa 70 or even 80 the differences may be a lot smaller when compared to these more similar motors.
E-8ight - Tekin RX8 2000kv/4S
stum
03.24.2009, 05:53 AM
I don't want the CC/Neu because it's a 2200kv motor! I'm running 5s and I don't want to gear down that much. Lower kv higher Voltage geared for the same speed is a more efficient setup. Also a small pinion and large spur that would be needed for the 2200kv on 5s isn't as efficient either. The closer the two gears are to the same size the less resistance there will be between the gears. My 1515 2.5D is 1650kv and I'm very happy with it, a little less power wouldn't be bad. A 1600kv Medusa is the closest I can get to this without shelling out another $260. I already have a 36-50-4800 in my crt.5 and the motor is awesome, I expect larger motors will be of the same quality.
Well I agree about the 5s, just make sure you can run it racing... many tracks won't allow over 4s hardshell. If it's open though and doesn't matter and you want to stick w/ 5s price wise you can't find a better option than the medusa 70 or 80mm. I would get the 70mm if you only want 40mph, if you want 50+ I'd say get the 80mm can.
To your point also.. I have a Neu 2.5d on 5s in my Losi 8ight-t conversion and it's perfect on the track :) I have the Medusa 36-60-2000 in my 8ight buggy and that too is a perfect home for it, the motor again wasn't quite enough for the truggy or erevo but is sweet on the buggy.
Good luck.
clink69
04.02.2009, 06:42 AM
I put the Castle 2200 on a converted Revo with twin 6S lipos. Well it just keeps twisting or breaking rear shafts. Used MIP CVDs, Integy. I guess they don't make any strong enough.. Was thinking to downgrade the voltage some maybe 4S or 5S.. I guess in the mean time I can pull the curve down to the desired voltage...
stum
04.02.2009, 08:05 AM
There is no drive train that will stand up to standing back flips for very long... the stock holds up just fine on 6s 2200 combo, wo a problem racing/bashing. When you twist a lot of drive shafts it tells you 1 thing, your slipper is on too tight! Back it off a bit.... typical event that causes the breakage is landing WOT on asphalt and/or concrete surfaces because they have very little give (from jumps or backflips). Again loosen the slipper and the stockers WILL hold up.. and don't land WOT, let off.. land then floor it.
George16
Supermaxx
George16's Avatar
04.02.2009, 08:28 AM
I still have to break any driveshafts/center shafts on my gmaxx powered by 6S lipos standing doing double forward or backflips . However, I have burned a couple of ESC(MMM and Lutcah's 6S) in doing so.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
asheck
04.02.2009, 08:47 AM
IMO 5s is the sweet spot , but hard to come up with for the E-revo chassis, If I had a conversion it's all I would run. As it is I like 4s just fine, for around 45 bashing it does great. Temps are never a problem.
clink69
04.02.2009, 08:17 PM
I am using 6S Heli batteries wrapped in foam. twin 3750Mah.. I was think to save some cash to back the curve down to max at 4 or 5S...
clink69
04.02.2009, 08:18 PM
It seems as soon as I back the slipper it toasts it. I have the RR dual slipper, are there better ones out there?
NoControl
NoControl's Avatar
06.20.2009, 01:15 PM
Getting ready to get my revo back up and running after I stripped the wheels. So I thought I should invest in a better motor, CCNeu 2200 seems to be the prefered choice but I'm debating thermal issues about it, I want a motor that can handle 6s with a 24/54 gearing and be able to go top speed on road, dirt, gravel, grass, or whatever else minus tall grass and the usual stuff that put excessive strain on the drive train and motor, but I want to keep temps below 150 in all those scenarios, equaly I want to be able to toss in 4s and gear the truck for 25-40, kinda hard to drive this thing in an area with a couple of trees, going 30ish. So I was thinking of getting a medusa, but couldn't remember what size most of you guys use for various trucks, checked around and narrowed my choices. However while digging up those numbers I came across this thread and noticed the strong arguement betwen medusa and CCneu.
So I ask you guys for 4-6s, good runtimes, low motor temps, and to be able to gear from 24/54 to 18/58, and without destroying axels, diffs, or flipping the truck into the next county, which motor would be a beter choice a CCNeu 2200 a Medusa 36-70-2000 a 36-80-2000 or another variant of the medusa line?
Thanks for any help guys.
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.20.2009, 02:02 PM
CCneu especially since you are going off road. The motor is designed for this while the medusa's are designed for airplane use. I have run the medusa's and they offer a lot of torque but again they are more designed for high air flow rate over the motor to aid in cooling. I think dagger's post above sums this up very well as others have said too.
Seeing as I don't see what vehicle you are going to run it in I can't gauge you on the gearging. However I will tell you that nothing out there will be able to run off road set up for high speed street runs without high temps.
I can run my LST2 with the CCneu geared for low 60's on the street and the temps stay in check, but if I try this gearing off road things heat up real quick. I have it now geared for low 50's which gives it good road speed and good off road power. I also have the throttle curve set so that from 0 to 3/4 throttle you only see about half power and get from half to full power in the last 1/4 of the throttle range.
www.cubicle101.com
NoControl
NoControl's Avatar
06.20.2009, 02:17 PM
Thanks for the extra info TSP, BTw 1st sentance says revo, I was just wondering since the lower the motors kv is the higher the input voltage accepted is without getting too close to max rpms and due to the higher voltages used the lower the current draw keeping all the stuff a little bit cooler and I just figured since medusa's are in my price range and that they offer a larger kv selction then the CCneus that a 2000 would be betwen a 1600 and a 2200 for a nice middle area to offer lower temps and a wider range of operating settings to allow between 40 and 75mph and the choice of 4-6s and as far as torque goes if brians calc is correct the medusa offers more torque in both 70mm and the 80mm cans but only by about .05 and axel torque is off only by .26 all the way around.
