Slipper clutch adjustment
Jason
Slipper clutch adjustment - 08.15.2009, 12:48 AM
does a to loose or to tight slipper adjustment can create more heating issue on the motor and/or esc ?
simplechamp
simplechamp's Avatar
08.15.2009, 11:09 AM
If you have your slipper too loose it will slip too easily, leading to excess friction and heat issues. Keeping the slipper tighter will remedy the heat issues, but your drivetrain will be more likely to get abused during hard landings and impacts. The key is finding the sweet spot that is in between.
As far as the slipper adjustment causing excess heat in the motor/ESC I'm not really sure.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.15.2009, 11:25 AM
If the slipper is excessively loose the motor will run warmer due to high revs, will also prematurely wear out slipper pads.
