Quark 80B
Thunderbruiser
Thunderbruiser's Avatar
Quark 80B - 09.19.2010, 02:22 AM
did a little research seems like it'll be fine for my stampede setup but not so much for the 1/8th
PS what would you setup guru's recommend?
I was thinking for the pede with 1/8th extension and pro-line moab tires
quark 80b and Feigao L sized motor maybe a 6 or 7L? also how would they perform on 2s cells maybe even the occasional 3s runs
would be geared for about 40mph not looking for top speeds just bashing at a local track that's it
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
09.20.2010, 09:07 PM
Do you have it already, or were you considering buying it?
I'd skip it really, go for something much more modern & with better support- MMPro or tekin RS for example. L can motor will be fine, feigaos do tend to run warm regardless, especially the higher kv models- I think if you're wanting to stretch a pede then go with 4s lipo & a ~2000-2700kv motor, rather than just 2s lipo and a ~3500kv motor..
crazyjr
crazyjr's Avatar
09.20.2010, 10:56 PM
I run a Quark 80 car esc in a rc10 GT conversion with w 1200XL lehner basic and 5s, for a lightweight truck like the stampede you will be fine. The Quarks have less heatsink area than most esc's, so you might need a fan for higher amp loads, Like L can fegaio and 2s
I also agree with neil, If you got it now, great use it. If you plan to get one, I'd go with something with support. Quark pulled out of America a few years ago
Thunderbruiser
09.21.2010, 03:28 AM
naw i was considering it but the deal didn't go through so I'll just get an MMP
garage:
simplechamp
simplechamp's Avatar
09.21.2010, 10:35 AM
I think you will be much happier with that choice. Ease of use and customer service will be much better.
crazyjr
crazyjr's Avatar
09.21.2010, 04:29 PM
I will say that as far as the quark VS the mamba max, the quark is still smoother and feels better. I can't say anything about the pro or the monster, But for their time the quark was the best out there. Too bad they pulled out of the U.S.
09.21.2010, 04:35 PM
The 80B is actually less than a MM current-wise. The 125B uses the same number and type of FETs as the original MM, so I would say the 80B is somewhat closer to a Sidewinder. The only advantage to the Quark is that it runs 5s prefectly fine.
As far as smoothness is concerned, a CC ESC with the newer firmware is very close, if not better, than the Quark.
Like people have said; if you have the Quark, use it. But if you are looking to buy an ESC, I would go with a MM or something similar. And I just happen to have a NIB MM sitting around.
