switch question...
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
switch question... - 12.12.2010, 10:20 PM
i know the monster mambas sometimes have bad switches. I'm not sure if i can call this one "bad", but it won't turn off. when i switch it to off, it stays on. i have to unplug it for it to turn off. anyone ever seen this one?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
12.12.2010, 10:36 PM
A switch can fail open or shut. I'd just cut off an inch out of case and solder together.
DwightSchrute
12.12.2010, 10:47 PM
thanks for the reply. i'll make sure i do that.
much appreciated.
bdebde
That's All Folks!
bdebde's Avatar
12.12.2010, 11:21 PM
I have one that does the same... right out of the box.
12.13.2010, 12:38 AM
A nice sealed heavy duty metal toggle switch would be my choice. Properly mount it and run the wires nice and secure...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.13.2010, 01:01 AM
Don't replace, upgrade!
http://www.allelectronics.com/make-a...SWITCH//1.html
12.13.2010, 10:42 AM
"on-off-on" SPDT is probably not what he wants, but would work. I use your typical on-off SPST switch like these and they work great. Mounting them is much easier than a slide switch and the insides are sealed. Rather expensive for a small switch, but can be found local. The key is to find a small switch with a relatively high current rating (~5A). These types typically have a more solid "snapping" action, so are less likely to self-actuate when landing jumps or whatever.
What's_nitro?
12.13.2010, 12:13 PM
??? The one I linked to is a regular 2-position toggle... It happens to be double pole, but there is no center OFF position.
Edit-
This switch might work better anyways... It's less likely to turn off in a crash.
http://www.allelectronics.com/make-a...-SWITCH/1.html
