yzinger02
yzinger02's Avatar
06.10.2011, 02:46 PM
It came with a 1518 thats 1250 kv, but that looks like a solid motor. Id rather just keep it instead of trying to sell it and buy that one. I was planning on buy the "important stuff" first, i was just wondering. Do you guys think 1250kv is too low?
florianz
06.10.2011, 03:14 PM
that sounds pretty good, I think 1250 on 6s is perfect. that's good, so you just need the esc.
yzinger02
yzinger02's Avatar
06.10.2011, 03:32 PM
Ok im liking the ezrun v2 150a on ebay for $104 or 105 shipped. The only thing i didnt like about the ezrun 80a i had in my emaxx is that the fan is always on and i think it shortens the run time a little bit. What mah do you guys recommend for 6s?
yzinger02
yzinger02's Avatar
06.10.2011, 03:38 PM
Thinkin bout these: http://www.hobbypartz.com/bluelipo6s25c.html or the 4000 mah: http://www.hobbypartz.com/bluelipo6s30c.html
florianz
06.10.2011, 03:43 PM
the fan does not cost relevant power. I think it's good that the fan is always on. I mean, who cares, when you're bashing you don't hear the fan.
you can go for 5000mah, but whith 6s you could even go with less, as you have less amps then in a similar 4-s situation.
you could test your 20s lipos, keep an eye on the temperature, and if they get ballooned. My cheap 20c Turnigy don't make any trouble at all. So before you throw them away, just have a try.
yzinger02
yzinger02's Avatar
06.10.2011, 03:49 PM
I wasnt going to get rid of the 20c's i just only have a 5s 20c setup right now and a 4s in 40c.
yzinger02
yzinger02's Avatar
06.10.2011, 04:16 PM
Is this worth $6 more or are they the same just the xerun is smaller? http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
JThiessen
JThiessen's Avatar
06.10.2011, 05:08 PM
Are you in Austrailia???? (that's where that item is being sold from)
PS. Dont waste your money on aluminum diff cases. Wait until you blow one - if you ever do. More for looks on the Losi MT's.
yzinger02
yzinger02's Avatar
06.10.2011, 05:19 PM
No im not in australia but i think its $111 USD. I just ordered this battery: http://www.hobbypartz.com/77p-sl4000-6s1p-40c-6666.html
yzinger02
yzinger02's Avatar
06.14.2011, 04:57 PM
Ok i bought a MMM brand new with castle link for $110 shipped! So now i beed some 17mm hexes because i bought savage ones because they were the cheapest and i just realized that the holes will be too small. The truck is supposed to get here thursday via UPS. I dont know when my esc will get here because it hasnt shipped yet. What gearing do you guys recommend for the 1250 kv motor with a 46 tooth spur on 6s? He had a 14 t pinion on it and it didnt look too bad but i dont think it will have any top end???
yzinger02
yzinger02's Avatar
06.14.2011, 09:19 PM
Do you guys know if LST parts fit the muggy or is it just LST2? I found a cheap parts lot but theyre LST parts.
yzinger02
yzinger02's Avatar
06.14.2011, 09:26 PM
And one last question: do I use Mod1 or Mod.8 pinions? Sorry for all the questions and Thanks for your time!
yzinger02
yzinger02's Avatar
06.16.2011, 09:54 PM
Got the truck today, and this thing is amazing! Sooooo much better than my emaxx, even though my dad thinks that my emaxx was a lot better. It just feels so much more solid! Anyway, the 8ight battery and reciever boxes fit like they were made for the truck (I think the chassis may be the same as the 8ight T?). The savage hexes I bought won't work, and i was afraid of that but they were only like $6. My esc is supposed to be here tomorrow, and I also got my battery today and I just soldered a traxxas connector on earlier. So, now all i need are some hexes after I get my esc. It came with the mud guards, and I put them both on but then realized that I had to take one off so i could fit the battery tray on it. One of the first things I did was raise the ride height and stiffen up the shocks, because this truck is going to get just a little bit of air I also used the motor fan that came with my sidewinder SCT system, even though it was for a smaller can the plastic stretched and I got it to fit. It came with a 16t pinion, so I don't have to buy one like I thought I did. So, now I'm off to buy some hexes!
mac3194
RC JUNKIE!!!!
mac3194's Avatar
06.16.2011, 11:36 PM
y do u need hexes if the muggy comes with 17mms??
I like to go HIGH with my RCs!!!
josh9mille
josh9mille's Avatar
06.16.2011, 11:59 PM
the muggy comes with 20mm hexes just like the LST2 and XXL
