Sylvester
Sylvester's Avatar
01.24.2007, 05:38 PM
I think the xl-5 is a pretty decent brushed esc.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
01.24.2007, 05:55 PM
well, I got the xl-5 in the mail today, im still waiting on my order from tower, along with a few other misc. items I have ordered, along with the tlt itself from Cali....so by monday I should be able to start cracking on it.....One question for those of you who have the tlt crawlers, pertaining to battery placement, do I need to place them as far forward as I can get them, cause i was going to try to mount the batts forward, and the rx & esc toward the back. Am I going about it right?
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
coolhandcountry
coolhandcountry's Avatar
01.24.2007, 07:26 PM
Originally Posted by emaxxjeremy
you'll probably want something smoother than the xl-5. there are several economical esc's that are decent crawler esc's, like the moped, rooster, etc
What is not as smooth on the hard pulls?
Have you tried the mamba jeremy? I have heard good things off the crawler forums.
The xl5 may be good in the rusty but under a crawler it has to be in a different
area.
Peace!
Country
Help support the
Rc-Monster
Buy here
rckcrwlr
Where are the Rocks????
rckcrwlr's Avatar
01.24.2007, 07:29 PM
I run the mamba with an outrunner...
Regarding the video...you gotta love the brushless chirping.
Bought my Wife a Rock Garden :027:
sven
sven's Avatar
01.24.2007, 09:49 PM
sjcrss:
Battery placement really depends on what you plan to do with the crawler. If you plan to do a good bit of vertical climbs, then the forward position is better than the rear. But putting the battery too far forward will negatively affect how well you can drive down a rock.
rckcrwlr:
Nice SW2, the brushless does sound really cool.
rckcrwlr
rckcrwlr's Avatar
01.24.2007, 10:03 PM
Originally Posted by sven
sjcrss:
rckcrwlr:
I second that one. My rig is set up with 60/40 Delrin High Clearance Links. I have 2 oz of BB's in the front and a stick pack on the front links. I can climb anything vertical. The problem is when going back down. The Ars end goes over the top. I have added 4 oz on lead on the back upper link mount to balance it out. Have not been able to try it out but if it doesn't work then the battery will go back there.
Thanks for the compliment.
GorillaMaxx360
GorillaMaxx360's Avatar
01.24.2007, 11:17 PM
nice pics of the under side how do you like the outrunner motor.
sjcrss
sjcrss's Avatar
01.24.2007, 11:18 PM
I plan on running 7-8 cells on the xl-5 since it is rated for up to 8 cells, what if i split the cells ( 4 up front/ 4 in rear) or 4 infront 3 in rear and have the motor facing forward, i plan on doing some vertical climbing as well...I guess I will have to just toy around with it
Bl E-REVO
Quark 125b
((2s2p)(4s)
rckcrwlr
rckcrwlr's Avatar
01.24.2007, 11:20 PM
Real smooth. Lots of torque with wheel spin when needed. I am running a 12T pinion that gives me a great balance. I had a GRU on it but it was way to slow. I think it was pulling up the asphalt in my driveway with all the torque.
GorillaMaxx360
01.24.2007, 11:21 PM
how do these motors compare to other brushless motors like the neus and lehners and will they work with other applicartions like an emaxx and why do not many people have them sorry for the many questions.
rckcrwlr
rckcrwlr's Avatar
01.24.2007, 11:24 PM
SJ,
I would suggest that if you want to split the cells go ahead. You want a little more weight up front. Add some BB's in the tires. They give you the weight at the lowest CG and also do not put strain on your driveline due to them rolling. If you strap weight on the rims that effects the drivetrain.
I would start with about 2 oz of BB's and then adjust. that is one of the nice things about using them. It is easy to fine tune.
rckcrwlr
rckcrwlr's Avatar
01.24.2007, 11:26 PM
Outrunners are more torque than RPM's. They have smooth acceleration and are brushless.
I run a Lathe in my super...may be going to BL there in the future.
sjcrss
sjcrss's Avatar
01.25.2007, 10:06 AM
so if i run bb's in the tires then just don't use any foams right, also i should put 4 cells up front & 3 in rear, i think that is my plan for the batts....i have all the stuff coming in the mail thru the rest of this week, and just trying to find out some more info is all
Bl E-REVO
Quark 125b
((2s2p)(4s)
rckcrwlr
rckcrwlr's Avatar
01.25.2007, 10:17 AM
What tires are you running? If you are running moabs or masher 2K's I would star cut the foams to keep the sidewalls from buckling. You will still get the grip.
sjcrss
sjcrss's Avatar
01.25.2007, 10:44 AM
i'll be running moabs, and how hard is it to cut them in the star pattern, it doesn't look to hard
Bl E-REVO
Quark 125b
((2s2p)(4s)
