difference between 2.5 and 3.3
concreat
Question difference between 2.5 and 3.3 - 04.14.2007, 09:56 PM
what are the differances between the revo 2.5 and 3.3 other than the motor size and lenth?
rchippie
rchippie's Avatar
04.15.2007, 01:51 AM
A noticable increase in power. The 3.3 has more bottom & top end than the 2.5 .
REAL MEN RUN BRUSHLESS
Serum
Serum's Avatar
04.15.2007, 01:59 AM
Yep, more power..
And it uses the 'new' 3.3 shafts, and the only difference is that the 'outputcup' changed slightly so it fits the new T-maxx 3.3 bulkheads. So nothing fancy changed.
So you get a more powerfull motor and a slightly longer wheelbase.
MetalMan
MetalMan's Avatar
04.15.2007, 03:04 AM
The 3.3 is extended in the front, so it pushes the steering servo(s) further back, forcing you to use longer steering linkages.
concreat
04.15.2007, 09:18 PM
well what would be the best one to convert to a E-revo then?
crazyjr
crazyjr's Avatar
04.15.2007, 09:31 PM
Depends, if you go gorilla the 2.5 is better, because you get the proper linkage with 2.5 chassis. If you use stocker chassis the 3.3 is better, because you need that inch of wheelbase
concreat
04.15.2007, 10:02 PM
i would b converting by my self like dafinays (dont know how to spell it)
rchippie
rchippie's Avatar
04.15.2007, 10:19 PM
you spell it DAFNI :027:
MetalMan
MetalMan's Avatar
04.15.2007, 11:38 PM
3.3 is better. Especially with brushless, the extra wheelbase helps tame the wheelies a bit :).
concreat
04.16.2007, 06:33 AM
cool thanks! does the 3.3 chassis fit on the 2.5?
crazyjr
crazyjr's Avatar
04.16.2007, 03:33 PM
In your case the 3.3 would be best
MetalMan
MetalMan's Avatar
04.16.2007, 04:46 PM
To put a 3.3 chassis on a 2.5, you need longer steering links (or just one if you're using one steering servo) and a longer center-front slider shaft.
Procharged5.0
Procharged5.0's Avatar
04.16.2007, 06:13 PM
I'll second that. You can find 3.3 rollers fairly easy theses days.
