RC10GT almost finished
nastety92
RC10GT almost finished - 05.30.2007, 06:46 PM
I just got my RC10GT back from Mike. He installed the esc, made the motor mount, made the battery box and supplied all of the parts.
Here are the before and after pics.
Link for the rest of the pics http://s142.photobucket.com/albums/r118/nastety92/RC/
I'm running a MM esc,
7S motor with RC-Monster heatsink
MaxAmps 5500mah Saddle Pack
I have a new steering steering servo that is not installed yet and the the receiver mount is temporary.
The problem I'm having at this time is the esc will not program to the receiver. When I go through the setup nothing happens. I turn the esc on, the red and green lights stay on and it only beeps as soon as I turn it on, nothing happens after?? Any idea what I might be doing wrong? All help would be greatly appreciated. While the truck was at RC-Monster Mike tested the truck with his own receiver if that makes any difference.
Also I would love to hear everyone comments about how the truck came out. I think Mike did a great job, I love the way it came out, cant wait to drive it now.
Thanks,
Nick
jnev
jnev's Avatar
05.30.2007, 06:53 PM
Can't really help you with the programming of the MM... but the rc10gt looks awesome. As always Mike does an awesome job on these conversions. Glad to see another converted st. You don't get to see these very much.
nastety92
05.31.2007, 11:45 AM
Thanks for the comments RC. The truck "looks" like a ton of fun, cant wait to get it going.
Nick
05.31.2007, 01:21 PM
I can't tell, but if your radio is a Futaba (or Futaba-based radio) you will probably have to reverse the throttle channel.
So you have the throttle trim set to 0 (centered) and the EPA set to 100% both ways.
nastety92
05.31.2007, 01:34 PM
I'm using the stock AE radio and receiver that came with the truck when it was a nitro RTR.
Nick
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.31.2007, 02:38 PM
I don't know how you guys have such patients on ur projects.. but the truck looks nice...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
skellyo
skellyo's Avatar
05.31.2007, 03:07 PM
Looks like he maybe used a modified Revo mount on there to mount the motor. I bet that saved him a ton of time in the fabrication. At any rate, it looks great and be sure and let us know how it runs...preferrably with some vids! :D
05.31.2007, 04:59 PM
Nick
OK, did you set the trim to centered and EPA to 100% (if available)? When calibrating the ESC, it needs to see a certain range of throttle throw. So, if you have the trim off center and/or EPA set funny, it might not want to calibrate.
05.31.2007, 05:01 PM
I figure if you're gonna go through the trouble of doing all the work for a conversion, why not spend a little more time to do it right so it's pretty and functional?
nastety92
05.31.2007, 05:07 PM
Thank you very much Brian, I will try this when I get home.
Nick
nastety92
05.31.2007, 06:06 PM
This is the radio that I have, I have tried it a bunch of different ways and I'm still getting the same result. I'm sure its just me doing something wrong.
http://www.teamassociated.com/shusti...adio/index.htm
Anything else I can check or try?
Nick
05.31.2007, 06:42 PM
I guess you could start with the obvious. Plug a servo (steering maybe?) into the throttle channel and see if you get it to turn. If so, then the signal is OK.
I know the transmitter in the picture was part of the package, but do you know if it is Futaba based? Some RTRs can come with the electronics from other manufacturers - they just put their label on it. Either way, you could try reversing the throttle channel and give it a go.
I assume you are trying to calibrate it to the ESC according to the ESC's manual...
nastety92
05.31.2007, 07:29 PM
Brian thank you very much for the help. Yes I'm going through the setup process per the manual. I can see now what needs to be done. I talked to Mike for a little while and he was helping me out on the phone. The problem is that when it tries to program the neutral setting it keeps rejecting it. I'm going to play with it a little more then try my receiver and transmitter from my stock e-maxx.
I also had my esc wiring plugged in backwards. Brown wire should of been out not in. I learn as I go, I'm sure these are newbie mistakes.
Nick
nastety92
05.31.2007, 08:58 PM
The truck finally lives. I got the stock traxxas receiver to work. The truck is pretty faster, wheelies on comand. The first time I went anywhere near full throttle it flipped on its lid and slid down the street about 100 feet, I was chasing after it in my slippers.
Thanks for the help getting it running, I appreciate it.
More pics and video to come soon.
Nick
silentbob343
05.31.2007, 09:15 PM
What got it working?
