Muggy diffs in a maxx
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
Muggy diffs in a maxx - 12.23.2007, 05:33 PM
Muggy diffs in a t-maxx, why you ask?? because in LST-2 diff cases these things are almost indestructible!
comparison of stock vs muggy, gray VS black (and im sure that 99% of aluminum bulks are cut like the black old school bulks)
any one with the FLM chassis could you please measure the height of you frame braces, im planning to use those but up side down thanks :)
rccna.com
its me
its me's Avatar
12.23.2007, 05:34 PM
rccna.com
cemetery gates
12.23.2007, 07:49 PM
So, what mods are need to do this(to the bulks/diff case)? It looks pretty cool!
Bye
12.23.2007, 09:58 PM
Very interesting, are the muggy diff cases the same as the lst/aftershock cases? These are the real hybrid diffs, parts from all over the place!
its me
its me's Avatar
12.24.2007, 04:44 AM
they are almost the same, difference is different pinion ring gear tooth count.
rccna.com
phildogg
phildogg's Avatar
12.24.2007, 10:21 AM
are these alot stronger than the maxx diffs?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
12.24.2007, 11:18 AM
Hmm, that looks very promising- keep us updated dude.
12.24.2007, 11:55 AM
phil
Yep, the lst/aftershock/muggy diffs are very similar to std 1/8 scale diffs, 6 gear spiders and you can get TiN coated gears for the lst 43/13 ration, which should help them last. I think my new 20xl hv maxx will use this mod, thanks its me for the great idea!
its me
its me's Avatar
12.24.2007, 06:01 PM
here you go George and for any others that have not seen the inside of a LST/muggy/8T diff.
very nice helical cut ring and pinnion
some have asked and yes the diffs are very very strong, my twin motor has yet to kill one yet.
rccna.com
12.24.2007, 06:43 PM
all i can say is zuuuuuurrrrrbbbbbbb......
12.24.2007, 08:25 PM
Originally Posted by its me View Post
In the above pic, what did you use as the metal shim to make up the difference in diameter between the muggy diff case and the hole in the maxx bulkhead?
Also, how did you get the retainer/locator ring to fit the nose(pinion) area of the muggy diff? The lst diff case I took a look at was larger in diameter than the inside diameter of the ring.
bdebde
That's All Folks!
bdebde's Avatar
12.24.2007, 11:46 PM
You can also get the ti-ni for the muggy ratio (45/11), just use Mayhem ST gears.
its me
its me's Avatar
12.25.2007, 12:34 AM
Drill/ dremel and PVC pipe for the spacer, try to get a tapered 1/2 PVC so when you slip them over the diff they wont pop out the bulk head.
rccna.com
its me
its me's Avatar
12.25.2007, 12:37 AM
you look right at the diff and you can see how much I drilled the yoke thingy, all of this only take about 15-20 minutes to do.
rccna.com
12.25.2007, 02:18 PM
Did you mention twin motored truck just now? I wanna see that thing man...
