Mamba Max temps?
Jeremy1976
Mamba Max temps? - 06.23.2008, 06:35 PM
Just ran my new E Revo out in the driveway for a couple minutes at the most on 4s. I am running the Tekno Neu 1.5d motor with 2 2s 8k packs. I temped my MM with my Raytek and it was 170 degrees. Sounds hight to me so I shut everything off. All my settings are on low. Any ideas?
SunnyHouTX
SunnyHouTX's Avatar
06.23.2008, 06:39 PM
Have you disabled the internal BEC by removing the red wire from the RX connector?
Jeremy1976
06.23.2008, 06:41 PM
Yes I did I took the entire wire out. From just calibrating it it got up to 114.
big greg
06.23.2008, 06:46 PM
wow i think you got a bad one
big greg
06.23.2008, 06:47 PM
hey sunny run that 8xl yet?
Jeremy1976
06.23.2008, 06:51 PM
Can you start a new thread or pm him about it? I am trying to get some input on my issue. Thanks
big greg
06.23.2008, 06:58 PM
sorry man, i understand you frustration, have you talked to castle yet? sounds like that one is just defective? how old is it?
Jeremy1976
06.23.2008, 07:05 PM
I got it off Ebay from a reputable seller that said it had maybe 15 runs on it. Yes it is frustrating.
No problem either bud just looking for some help. I tried calling CC but they were closed. Will try tomorrow again.
SunnyHouTX
SunnyHouTX's Avatar
06.23.2008, 07:09 PM
Not yet. Man those motor wires were mangled so I had to put fresh heat shrink on them and clean everything up. Will be using it pretty soon.
And to answer Jeremy1976:
Do you have any binding in your driveline? Have you tried changing gearing? Say to a smaller pinion or larger spur? You can't use the same gearing as you would on 3S without getting heat issues.
phatmonk
RC carbon junkie
phatmonk's Avatar
06.23.2008, 08:32 PM
Are you running a fan on the ESC this makes a big differance. Also Double check you motor wires.Ive had my MM overheat because my 5.5mm motor bullets werent soldersd correctly.This will be acompanied by cogging at low RPM.I also have a Tekno Neu 1515/1.5D and since my MMM is being repaired Ive been using my MM with a BEC set at 6.0 volts and a Novak fan on 4s in my 8T.
