I'm running a normal c-50 in my maxx, however i've just bought a special limited edition c-50, which look's awesome.
The only down side of the motor i'm buying, it's got a broken spool(pinion snapped off). Now my original plan was to use the spool of my current c-50. But since i've always been slightly consurnd about the weak 3,2 mm shaft, are there any other spool's that will fit the c-50 but with a 5mm shaft?
Also does anyone happen to know the kv rating of the c-50's?
Depends on the wind(Kv is determined by the windings, not the magnet). Pretty sure a Feigao or Hacker shaft would fit right in, but there are some issues to this theory. The best for that motor would be a Hacker rotor(make sure proper clearance from shaft to windings), with a 5mm shaft. I say use your current motor's shaft and keep the pinion closer to the motor can when you mount it to avoid the potential for a broken shaft(most times, the shaft is broken due to high stress when the pinion is mounted way out on the end of the shaft-leverage will win!).
In this case the previous owner had run his gmaxx with a tight slipper and hit a car tire at full throttle, while during the crash still giving throttle. Since the motor didn't had a chance to get the power away, the shaft broke.
I have two of the C50 maxx motors. Ran them as a dual set-up until the one motor broke the shaft. Than ran the other motor as a single. It lasted about three packs before that motors shaft broke.
The shaft on these motors must be WEAK as there were a good number of people who broke shafts on these motors. A 5mm shaft would be a wise choice.
Thank you,
Promod
Actually(and I have to knock on a piece of wood really hard this time) this motor seem's to be holding up well. From full speed to spinning the tire's in reverse on a normal road. I really thought i'd hear something snap, including my stock tranny, but it didn't. Guess I was lucky.
Why not contact hacker usa about it? Not always the fastest I know but just don't tell them it's for an R/C Car (otherwise they scream bloody murder). I think they make 5mm shafts for the c50 cans, just not the maxx editions.
