Best methods to lock a center diff??
mac3194
RC JUNKIE!!!!
mac3194's Avatar
Best methods to lock a center diff?? - 01.03.2011, 08:43 AM
I am making an offroad 5th scale using a center diff but i want to lock the center diff and i want to now the best/easiest method. Ive already tried using 100,000WT oil but my center diff leaks to much...
Thanks for any input
I like to go HIGH with my RCs!!!
01.03.2011, 09:26 AM
Cen diff locker...
Lock it up.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Lock it up. - 01.03.2011, 09:36 AM
Well it all depends on whats available for your particular vehicle. Some manufacturers make a spool for them, which acts like a stright through axle. You could also try using several different substances in order to achieve your goal. You can try using a very thick grease which would still leave you a slight slipage, or even go all out and use something like gorilla glue in the diff cup. Of course it would be vertually impossible to change it back to a limited slip diff if you lock it up with glue. Acquiring some kind of spool or even making one yourself would be your best bet I would think.
SUPERMAXX YOUR LIFE.
florianz
01.03.2011, 10:42 AM
you can take hot glue. When used on oily gears, it can be removed later.
or you get a torsen diff (or lsd-diff by losi, xray etc.). a torsen (I have it in the center) locks under load, up to 80 %.
01.03.2011, 10:59 AM
The cen diff locker is the best bet, or use glue/jb weld for a permanent lock.
junkman
01.03.2011, 01:57 PM
I use silly putty, works fine on 1/10, and 1/8 cars, can be undone if needed, and $2 gets you enough for several diffs. Just pack it as full as you can get and tighten it down. My theory is it is a touch more forgiving on gears and cv shafts, as it will have a tad bid of give over being mechanically locked.
simplechamp
simplechamp's Avatar
01.03.2011, 03:45 PM
I think I might try Shoe Goo or Amazing Goop (similar stuff from the same company). It should set up a bit firmer than putty, but you can still remove it later with a hobby knife or pick. Silicone sealant would probably do the job too, and be removable.
I have a plenty of stock diffs and diff parts laying around, and wouldn't mind using JB Weld on one to make it permanent, but I really don't want to do that to my Slipperential.
mac3194
RC JUNKIE!!!!
mac3194's Avatar
01.03.2011, 04:20 PM
Well i have a spare center diff so idc if its permanent and the diff is from a duratrax raze i think i might try hot glue since i have some at home or i can buy some putty at rhe dollar store...
