agw
11.24.2012, 10:27 AM
Understood, thank you.
At this point I'm thinking of going XO-1 but I'm not sure on which wheels. I really like my aluminum ones but I'm not sure I want un-glue the rest of my tires and reuse them.
agw
11.28.2012, 09:58 PM
Originally Posted by Klausen View Post
I run Traxxas 17mm hex's with Proline Badland, on the original shiny 2,5 MIP cvd's. I had to mod the Traxxas hex's a bit by drilling from the backside, to make them go far enough into the cvd.
Nice looking truck!
I ended up getting HPI 17mm Hex which use the same size pin I already had (2.5 X 12) and a set of Sweep belted tires already mounted on black wheels. Not as nice looking as the aluminum ones but they feel really solid. I doubt the would balloon at all.
Given the smaller radius, the new theoretical speed is now 71 MPH. Let's see how hot the Schulze gets before I hit 50mph
Name:	2012-11-28 21.12.58.jpg
ID:	10561   Click image for larger version
Name:	2012-11-28 21.12.19.jpg
nastety92
11.29.2012, 09:09 AM
Here is another option if you go with a 17mm hex. Monster truck/ Truggy belted slicks.
http://ipanemasports.com/MonsterSlicks.aspx
(stolen from snellemin)
Nick
Tamiya TRF801Xt-e
Justinbolin
Hugo Stiglitz
11.29.2012, 09:26 AM
Nick
That page didn't come up for me.
Can you repost it, I'm curious about the 17mm belted slicks.
Thanks,
- Justin
  Send a message via Yahoo to Justinbolin
Justinbolin
Hugo Stiglitz
11.29.2012, 09:32 AM
Good looking truck by the way
[1] Gorillamaxx G4 w/Flexteks
[1] Gorillamaxx G4 w/RacerX
[1] Gorillamaxx G4 w/G3.3
"No one can resist my Schwetty balls"[/B]
nastety92
11.29.2012, 12:40 PM
Thanks,
- Justin
Try this one,
http://www.ipanemasports.com/Pages/M...uckSlicks.aspx
Tamiya TRF801Xt-e
11.29.2012, 01:03 PM
^^thanks nastety
Those monster slicks are perfect for monster speed runs. I sent ipanema an e-mail, just double checking that the Monster Slicks are indeed belted. If they are I am getting a set!
agw
11.29.2012, 02:53 PM
Nick
They look cool but at 139mm they are just about the size of the stock emaxx tire which would be way too high for the gearing I'm stuck with.
I may get a pair for my other Gmaxx though. Let's see what they say about being belted or not.
nastety92
11.29.2012, 04:31 PM
They are belted. All of the ipanema tires are belted.
If they Monster slics are to big look at the buggy slicks. They also make buggy size belted street tires, not slicks.
Nick
Tamiya TRF801Xt-e
agw
11.29.2012, 04:39 PM
Nick
Yes, I saw those as well but I have to say, just got back from trying out the Sweep Slick 55 and I had a blast. No ESC overheating, a good degree of drifting until they warmed up a bit, much easier to drive.
Meanwhile I lost a wheel because the nuts are not right and the nylon part does not reach so they come loose easily. I'm waiting for the HPI nuts and hopefully they'll work better otherwise I'll need different CVDs.
I took an on board video which I'm hoping to find the time to edit.
11.29.2012, 04:59 PM
You can spin those nuts and put the nylon part on first. If it's a flanged nut just use a washer for the flange. Also, loctite is your friend
agw
11.30.2012, 12:14 AM
Not a bad idea at all but it turns out that the flanged nuts I was using were just too big. I switched to the same M5 I had before and put a little washer instead. Now I have no problem...well not that problem anyway...
Must find a large parking lot with no cars...
first run of tires not belted
mikesauto
mikesauto's Avatar
first run of tires not belted - 11.30.2012, 07:16 PM
hope they fixed them
http://www.rctech.net/forum/monster-...-slicks-3.html
150 a set of 4
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
