Programming MGM 80 amp with 5300
widemouthmaxx
widemouthmaxx's Avatar
Programming MGM 80 amp with 5300 - 05.27.2005, 05:11 AM
I've been hounding Mike with pm's so I thought I'd ask advice from others on this one...I got the motor and ESC all soldered up nicely. I will be running either 6-7 3300 cells in my MF2 with 19-21 tooth gearing...the set procedure seems pretty easy after reading it a thousand times :rolleyes: anyway I think I got it now..so anyway when it comes to a couple of parameters please give me the best setting for the following:
Timing? (what is timing anyway?)
Range of Neutral Zone?
Automatic Correction of the Neutral ater Switching-on?
....other than that it all looks good...alos what would be the best solution for keeping dust out of the motor..there is a lot of space where the wires come out
Thanks
RCcarnut
05.27.2005, 08:38 AM
I have seen people use silicone or something like that but I worry about it melting and getting into the motor. I like to just put a piece of tape over the area where the wires come out. My latest 5300 I used some larger shrink tubing and put another layer over each wire, I put it all the way down, close to the hole. This made the hole going into the can much smaller and gave another layer of added protection to my wires. Then I just cover the rest of the hole with a small piece of tape.
You definately want to use something though in dusty conditions. My first 4200 I did nothing and within a couple weeks it was full of dirt and not running right.
lipomax
05.28.2005, 02:16 AM
just caulk the hole. Don't fill the can with caulk though - a thin superficial layer around those wires should do fine. You can just put a balloon over the rear of the motor with the wires sticking out too.
widemouthmaxx
05.28.2005, 03:44 AM
Thanks guys for all your input but I'm still in the dark about timing???
Even the simplest advice would help considering I have no experience in this area
Thanks
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.29.2005, 09:24 AM
I use a high temp rtv silicone around the mtor wires. It won't melt and keeps the bad stuff out. For timing, leave it on automatic timing.
