xcntrk
xcntrk's Avatar
04.09.2008, 03:50 PM
Originally Posted by neweuser View Post
IMO, running 51/20 is over geared with UE Diffs. You should be at 16 or 17 pinion with mod 1. You will find your sytem much much happier. The temps calculations is an estimate only, and not ALWAYS the case. Another problem could be a connection somewhere as well. Also, you are running a ubec correct?
Yes, I have heat modifications to help the MM run with a 25C 5000mah 4S pack including a Novak cap, fan on the heatsink, and CC-BEC with red wire pulled from the esc plug and fan wired off BEC.
With my config the motor rpm is just above 35k. Not sure if that’s related but may be close to the ceiling for a Fieago?
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
