Emaxx_Quebec
Emaxx_Quebec's Avatar
03.05.2009, 04:21 PM
Then I had to shave the drive shafts a little bit too. After that, it was A LOT easier to install the pins.
finished with RCM 8mm Drive cup - Kershaw dog bone
I have a Ofne 51t mod1 spur 20t pinion with Bidpruduct 36/74 8xl 2075KV Motor with 43/13 diff ratio,
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 20
Total Voltage: 14.8
Motor KV: 2083
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 83
Motor coil Ω: 0.0084
Spur/Pinion Ratio: 2.55 : 1
Total Ratio: 14.52628 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 29376.13 RPM
Vehicle Speed: 34.89 mph (56.05 km/h)
Effective KV Value: 1984.87
KT constant: 0.65 oz-in/A
Motor Torque: 0.28 ft-lbs
Final Torque: 4.08 ft-lbs
Final Power: 1228.4 watts (1.6 HP)
ps: I'm french speaking so my english is not perfect.
