Oppressor
05.31.2009, 11:08 AM
If you really want to run all day long at 80 mph, you will really need a good esc and motor.
While the brushless record for a mt was done with a neu 1521 i really don't expect that setup to run for long. A good finned 1527 with a fan is probably the minimum... The 1527 being nearly twice as strong as a 1515, i would certainly consider the 8mm shaft option...
As for esc maybe a castle hydra hv?. If you want a true car esc that can handle lot of power and money is no object then a schulze 40.160 is certainly a potent esc.
