swiftneed
swiftneed's Avatar
03.23.2010, 10:08 AM
If the hex is flushed up against the chassis; you can try to use the method with the dremel,making a slot like Hautz mentioned which is easy but have enough head on the hex to do but it sounds like you went at it and its worn; opt to use the easy out if you can drill nice and center smallest bit and slow
