thzero
03.25.2010, 10:08 AM
The standard Flux one would only work on a can the same size as the standard Flux motor. It won't work with the 2200kv from Castle (same as the Flux) because it has a different can fin configuration.
That mount doesn't look too bad. Something like this from RCM would be great!! (hint Mike!) :)
If you are using Flux plates (or equivalent like the TCS... see my thread about 5T conversion) you aren't able to use the nitro motor plates. Its a different size with different attachment locations.
Originally Posted by jediguru View Post
I'm in the midst of a flux conversion and am trying to get my parts sorted out that I need. Looking at possibly getting the TCS chassis plates and hpi motor plate. However I have my doubts whether the hpi motor mount will work with my motor. I have a hobbyking 9XL. So, I'm looking at possibly getting this mount http://204.186.93.64/MotorMounts-Savage.html. Its the one at the top of the page. This mount is meant to be used on the holes in the engine plate where the nitro engine mount would normally attach to. My question is A. can the nitro motor plate be used with the flux chassis plates or B. is the hole spacing on the flux motor plate the same as the nitro motor plate. Hope this is clear enought to understand.
