auto2
03.15.2012, 06:54 AM
Originally Posted by FG101C View Post
It's diffing out to the front a lot. From my experience with brushless motors, this is just my experience, brushless motors like a load. Diffing out may be causing the motor to run with less of a load causing slight over revving. I fixed this same sort of issue in my 1/8th Truggy by going to a thicker center diff oil.
In my baja the 2028 was running hot, so I went up two teeth on the pinion and it coooled down some.
Again this is just from my experience, I'm by no means saying that's the problem with your truck or saying I'm an expert at this...end disclaimer.
i have 30000 dif oil in the center and its still diffing out lol
well this is interesting cause i though it would of run hotter on the street using a lot of brakes and basically dragracing over and over but it ran hotter on a dusty track with no real traction with a 17 pinion where i had an 18 on the street. i probablly didnt drive it for 12 minutes on the street though cause bashing gets boring to me real fast. plus it was 45-50 degrees during the street test and the track test was 70 degrees f
