wire gauge
MMMM
wire gauge - 02.12.2005, 12:06 PM
The wires on my BK are like 12 gauge wire, and the wires on my gp 3300 packs are smaller (like 14 gauge.) Are the wires on my batteries a limitting factor in my brushless setup?
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
02.12.2005, 12:59 PM
The smaller wires can technically transfer less amperage, but I doubt you would notice a significant difference if you changed them. I use 12 guage wire myself, but the 13 or 14 guage should be sufficient.
MMMM
02.12.2005, 04:08 PM
My packs came with thin little tabs connecting the batteries. I doubt that larger wire would help anyways.
RC-Monster Mike
Site Owner
02.12.2005, 05:51 PM
If you are using stick packs, the point is pretty much null and void. The tabs are the limiting factor in your cae (thin metal that connects the cells).
Serum
Serum's Avatar
02.12.2005, 07:13 PM
Mike, about that thin metal tabs;
That depends on the pack manufacturer. My stickpacks are soldered toghether directly. Without a crappy thin bar.
my packs are also built with GP3300's
RC-Monster Mike
Site Owner
02.12.2005, 09:04 PM
True. The end to end soldered packs are the best (better than using battery bars) when built properly. Less resistance. My comment was directed towards mmmm's comment on his own batteries (I assumed they were stick packs based on his description) and most production stick packs. A few smaller battery re-sellers do the end to end soldering. I haven't seen any "big" battery sellers doing this type of construction, though. If you know of any, let me in on it, will you! :)
HotnCold
HotnCold's Avatar
02.12.2005, 11:22 PM
Want me to find out about the hammerhead attachment for my old soldering iron there - Mikey sir????
Hows that "Hope and Change" working out for Ya???
Serum
Serum's Avatar
02.13.2005, 05:13 AM
Hopf in Germany uses this technique.
Here they are.
I thought BK (lehner) makes them the same way.
RC-Monster Mike
Site Owner
02.13.2005, 10:49 AM
Serem,
Maybe they do. I get my batteries from the states, though. Shiping is expensive enough from overseas for the light stuf. Not to mention customs! The end to end packs are the best way to run high cell counts for sure, especially with the Schultze controllers!
HotnCold,
Any info on the attachment would be great. We need one to play with. Thanks.
MMMM
02.14.2005, 09:54 PM
Mike, these are the batteries I bought and was talking about. The seller used thin tabs to connect the batteries together. I don't think they are thick enough because the plastic wrap over the tabs have melted because of the heat. Too much resistance I guess.
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
MMMM
02.14.2005, 09:56 PM
The ad says these batteries come with 12 gauge wire. That's a lie! Those are 14 gauge wire.
RC-Monster Mike
Site Owner
02.14.2005, 10:37 PM
Yep. The cells seem good, but the thin "battery bars" are a limiting factor in power output, and are no doubt causing the heat/resistance. It would be easy enough to rebuild them with better battery bars. It looks like 14 guage wire to me, too.
