silentbob343
05.31.2007, 09:15 PM
What got it working?
05.31.2007, 09:49 PM
Sounds like he changed to a Traxxas receiver/transmitter...
silentbob343
05.31.2007, 09:59 PM
ahh I see I glazed over the post where he said he was going to switch to his traxxas tx/rx.
05.31.2007, 10:00 PM
lol, NP. It happens to all of us.
05.31.2007, 11:36 PM
LOL, is that text big enough? I can't quite make it out. :)
That's nice to know though. Although, I probably won't remember that next time, and will spend about an hour trying to search the forums for this information.
Anyway, it was just an idea. I was also going to suggest opening the EPAs to as wide as they could go and then make small adjustments to the throttle trim as the next step, but since he replaced the radio already, it's a moot point.
nastety92
06.01.2007, 04:38 PM
Thanks again Brian for the help. The TX receiver/ transmitter worked very easily. I got to drive the truck again today, and I'm really impressed with it. Now I just need to get my battery charge so I can charge these batteries.
Nick
06.01.2007, 11:20 PM
Nick
No problem. It's too bad we couldn't get the stock tx/rx set to work though. The only issue with using the stock Traxxas radio is that it is AM and might be prone to interference from the BL components. If it works though, great!
nastety92
06.02.2007, 07:57 AM
I'm sure if I played with the AE receiver/ transmitter a little longer I could of got it to work. I got it to program completly but when I pushed the trigger to go forward it went backwards. After that I couldnt get it to program anymore, so I moved on to the traxxas. Right now I'm not getting any interference, if I do in the future I can always go to an upgraded receiver/ transmitter combo.
Nick
crazyjr
crazyjr's Avatar
06.01.2007, 10:49 PM
All transmitter/reciever sets on 27mhz AM, EXCEPT for airtronics, are using the same crystals. I have seen futaba Trans. and JR recievers together, Traxxas and ace (associated and thundertiger radios) together. The part about airtronics is something i heard, so not sure
06.02.2007, 12:32 PM
Oh! All you had to do with that is swap any two BL motor wires! That may happen no matter what you use.
nastety92
06.02.2007, 03:31 PM
I did swap the wires, but when I did that I needed to reprogram the esc again, thats when I couldnt get it to work correctly. Then I switched to the Traxxas receiver/ transmitter.
So far the TX rec/ trans has been working great. I got to drive the truck a few times today for a few minutes each. The truck is really fast, it feels like I took the stock four cylinder out and installed a big block.
Nick
