supralover72
supralover72's Avatar
08.26.2007, 12:46 AM
Hmm, can you split them up? Try mounting all the elecs in the center, then if your doing a G-maxx, put them in the batts slot, maybe 7 on one and 7 on the other or 3 on one and 4 on the other as I blanked on weather 7s2p has 14 or 7 cells ;).
Or, make a plate over the shocks and mount some batts or the elecs.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
08.26.2007, 01:24 AM
This is the stock Revo 3.3 chassis we're talking here, there is no batt tray.
Also, I have to fit that 'monster' Monster 125B (Avatar) somewhere too, maybe on a mount on top of shocks like you said?
Do you know how much room there is between the revo tranny and the body as far as width on the right side? I basically have the whole right side to work with here, so either two seperate 7s packs on each side (not my favorite idea), or one whole 7s2p brick on the right side.
That fact that it's an 'odd' 7s pack makes it more difficult, IMO.
zeropointbug
Z-Pinch racer
Smile 08.26.2007, 01:30 AM
Thanks Finnster, does the body hit that batt tray at all?
This makes me wonder, can Mike make a large custom battery box, that is sealed? Like the TrakPower packs. That would be ultimately what I would want for this, nice and clean, protected, and just plain would look cool.
ZPB
Finnster
KillaHurtz
Finnster's Avatar
08.26.2007, 01:42 AM
Well no, but I assume you are going to make one, yes? :p Your intended layout will determine the design. That's what I mean
Between the center tranny "bell" of the chassis and a stock body is ~50-55mm. My tray is ~48mm +1/4". The body touches, but is not pushed out. I put a side guard on to protect/secure lipos. With A123s you could cut this out. You could angle the tray down if needed to get some space. Really you are going measure the chassis out w/ your batts to see how it can fit together. I curious to how you going to build the pack, as a 7S is an odd #. A double shotgun pack may be nice and low cg, but will be tricky to fit.
zeropointbug
Z-Pinch racer
08.26.2007, 01:56 AM
I was actually referring to Supralover...
Anyways, there sure isn't much room to work with on a Revo compared to an FLM maxx chassis! But, when done right, the Revo's just look so excuse my language, damn nice!
I am thinking one 7s2p brick on the right side, in a black plastic case (if Mike can make one), having the cells laying up and down? I hope that will work, that is definitely one option.
zeropointbug
Z-Pinch racer
08.26.2007, 01:57 AM
Yes, I will be using the Revo tranny w/ mod.
