mwry13
mwry13's Avatar
10.09.2007, 10:03 PM
Originally Posted by Hakan_J View Post
Well either get a motorclamp from Mike or make the mount support the rear of the motor somehow. I have heard several ppl use JB weld on the cap when they have gotten loose, seems to work. The problem is that if it popps loose it could damage the motor :(
im actually converting mine also but ill be throwing the motor behind the steering servo.. ill be running a 4s1p setup with Neu 5000 Mah 30c Batteries :) neu 1515 1y/f also for the motor :)
