Matthew_Armeni
Matthew_Armeni's Avatar
01.05.2008, 03:53 PM
Seriously? 3s on a revo is your standard setup??? Thats makin me wonder how that clutch setup will stand up to 4s, 5s and even 6s power that some will throw at it. Have you done any testing with real power in it?
3S and a higher kv motor and 6S and a low kv motor will effect the clutch in the same way. You're still gearing for the best performance and power output is similar (for the most part). How they effect the ESC is another story.
Also, he only said that that this was his setup right now. I'm sure he tries many setups looking for the best ones, even if it may seem unconventional.
  Send a message via AIM to Matthew_Armeni
jhautz
jhautz's Avatar
01.05.2008, 04:05 PM
a higher kv motor on 3s and a lower kv motor on 6s is not even close to the same thing! WAY more potential energy with the higher voltage. Way more power for the clutch to harness and transfer.
I was just very surprised to here 3s was his standard revo setup. General consensus around here is that 3s is not enough power for a Revo to be effective, which it sounds like he agrees with. As he said... when its geared for enough power on 3s it lacks the top end speed he needs. But the fact that he had "so many" 3s batteries around told me that was his standard setup. It did sound like he tested it on 4s, in the past though. I have taken the clutch setup and put it into a 1/8 buggy to run on 5s but havent had a chance to get it out to the track yet. Hopefully next weekend and I'll then find out for myself I guess.
Anyway... I dont want to hijack Davids thread so I'm done here.
to make it...
or break it...
Silent...But Deadly
