01.14.2008, 12:26 AM
Good to know Tim, I want to leave the stock ss kit 2 speed if at all possible. I will set the slipper slightly loose. I killed the shift clutch? in my revo, it used to shift really hard into second, and then stopped. I rebuilt the tranny with a wide ratio gearset and a new shift clutch. I have not had a chance to test it yet, but I will set the slipper looser now, and see if it helps.
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
01.14.2008, 12:48 AM
The trick is to set the slipper still tight enough that it doesn't melt as well. I almost melted mine when I put my LRP .28 in. I would set it just a 1/4 of a turn back from tight and just check that it is not getting too hot.
