04.27.2008, 01:42 PM
Originally Posted by BOOGIE444 View Post
Nice setup, I like how you use heat shrink tubing to attach the antenna wire to the side of the antenna tube, I do the same thing! I can never get my old beat up antenna wire to go through the tube, hell I cant get new wire to go through the tube either but thats another story
Well, if you put a little glass cleaner in the tube, it makes sliding the antenna wire through much easier.
That is actually masking tape I used, but I will try heatshrink now that you told me! I do have the wire in the tube, but there was alot of extra that I had sticking out, so I taped it to the side. I usually finalize my electronics mounting as I test a setup. I usually takes a dozen runs to get everything just the way I want it!
ZAX
ZAX's Avatar
05.03.2008, 02:55 PM
I really liked your motor mount I would like to copy it if you donīt mind?
What is the measurement of it??
05.03.2008, 03:04 PM
Sure, I do not mind if you copy it. As for measurements, I will have to get them next time I take the truck apart. All I did was cut the al angle until it fit the space, and left enough room on either side for it to slide for gear adjustment. I then took the plate out and out the motor in with the pinion on it so that I could make a mark where the center shaft would have to be. I made the mark on the nitro motor plate, and then place the motor mount back in and transfered the mark to it. I used a 14t pinion, so I figured that that would be the about halfway between the smallest and largest pinions that I would want to use. So when I transfered the mak I made sure the motor mount was set in the middle of the adjustment slots. That way I had room to slide it close or father ways from the spur. Sounds more complicated than it is.
BitHed
01.08.2009, 02:16 AM
...pictures are blocked at work so subscribing so i can find it later on :D
...Sounds like you have it pretty sussed lincpimp...Good job...
01.08.2009, 02:49 AM
Thanks, this truck is for sale actually... I just stopped running it and it is taking up space...
BitHed
01.08.2009, 11:47 AM
...finally got the pictures :D Clever motor mount LP Simple is best...Did you / would you consider making them for sale?
