Dadx2mj
Dadx2mj's Avatar
06.20.2008, 01:35 PM
I used a Novak fan on my MM that plugs into the receiver. It lowered my ESC temps from the 135º-145º range to around 110º running on a 2s lipo
Blindman Racing
Powered by Mamba 5700
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
06.20.2008, 01:36 PM
So you lowered your temps from perfectly fine to really low, and got to waste runtime because of it. MMmmmmmmmk.
Dadx2mj
Dadx2mj's Avatar
06.20.2008, 03:46 PM
Wow what a negative attitude. The tiny amount of current the fan draws is not effecting my run time at all. Even if it did with summer coming on it would be well worth the piece of mind it gives me knowing the ESC is staying as cool as it can.
Blindman Racing
tc3_racer_001
tc3_racer_001's Avatar
06.20.2008, 07:56 PM
i agree with dad. seriously, that extra cooling would probably add to the efficiency, and you would probably get a longer life out of the MM that if you had no fan...
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Wakesurfer
06.20.2008, 09:59 PM
4s on MM in 3905 with Neu 1512 1Y, geared 18/68 (with CC BEC) runs in the 140s with twin fans and holes in the case. Loose one fan and it thermals in a couple of minutes, so I'd say the twin fans are what I need on mine. Heat increases resistance in electrical circuits/systems. If you can keep it cooler, you will waste less power on internal resistance, which will cause more heat as resistance goes up. Do the fans IMO.
sleebus.jones
06.27.2008, 08:35 PM
Negative? How is pointing out pointless mods negative? What you did offers ZERO benefit, and actually creates a performance hit.
I wouldn't even consider a fan unless my ESC ran 180, I had tried everything to lower it and had no success. I run in Houston (yeah, where the real summer is) and I've not had ANY heat problems EVER running 2S. Putting a fan on a mamba 2S system is just laughable.
I guess if it makes you happy, go for it.
Jeremy1976
06.27.2008, 09:03 PM
Well I had to put a fan on mine. I ended up buying another brand new one and swapped them out and put the deans connectors on just to see if that may have been a issue. Same thing, up around 200 degrees within minutes with all my settings as low as they go. I put the novak fan on and temps were around 130-140. Ambient temps here were 72 degrees when running. I am running a Tekno Neu, 2s 8k lipos, (4s), 22/58 gearing, CC BEC.
azjc
06.28.2008, 03:17 AM
its only 72 degs....when I wake up @ 0700 its pushing 90 degs here....:-0
Dadx2mj
Dadx2mj's Avatar
06.28.2008, 11:39 AM
Believe what you want I am a firm believer in cooler electronics work better for longer. You thinking the tiny little fan is going to hurt performance is what is laughable.
Blindman Racing
Wakesurfer
06.28.2008, 12:07 PM
Hasn't been to bad here yet this year, but 100dF with 99.9% humidity is not unusal for a St.Louis summer. I probably wouldn't need a pair of fans for a 1/10 2wd ST, but a 3905 Maxx on 4S puts a little more heat in the ESC.
phatmonk
RC carbon junkie
phatmonk's Avatar
07.14.2008, 09:23 PM
Heres a photo of my 30mm Magnetic Levitation fan on my MM.This little baby puts out 4.9cfm.
tc3_racer_001
07.15.2008, 03:54 AM
where can i get one of these???
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.15.2008, 08:05 AM
How much does that cost and where did you get it from?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
07.15.2008, 05:22 PM
$15-$20 posted i would get one... and hope it wouldnt break. anything more and i probably wouldnt bother seeing as i can get 5 and 12v fans for $7, sometimes with a cheapo heatsink!
are these available worldwide as ive never seen or heard of them before
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Phatmonk
cobra
Phatmonk - 07.25.2008, 06:05 PM
I was looking at your picture of the cooling fan on the MM. I see the heads of 2 screws or bolts. How did you attach it to the heatsink?
