Ryu James
Ryu James's Avatar
10.04.2008, 04:30 AM
Originally Posted by Unsullied_Spy View Post
I wouldn't worry about it. That motor can actually move a 1/8th buggy OK with proper gearing. By my estimates, as long as your battery can put out 110 amps it'll be fine. That lipo is a 25C pack, right? If so, it should work without a problem. A 20C 5000 mAH lipo would work, but it would get strained a bit under heavy loads (proper gearing and it probably wouldn't be an issue).
it does better than move a 1/8 buggy ok. i have that motor on a Losi 8 and it flies at 50+ mph. if i gun it the thing will wheely right over. however, this is with a 4s. i use losi's new 4s battery. 25c i think. perfect combo in my opinion. max rpm with the 4s is right about 40k rpm if i recall. that motor can handle 60k rpm.
david lamontagn
10.04.2008, 09:02 AM
Perfect!! and i'am plan to buy a crt.5, and i'll put this motor in it on 4s too. Maybe too much power for a crt.5, but what do you want, i'am crazy
Ryu James
Ryu James's Avatar
10.05.2008, 12:18 AM
no, i think it could be awesome! i am wanting to do the same thing. i was bidding on a CRT .5 Rc Monster BL on ebay and then the seller backed out of the sell. i was bummed. he had the velineon 3s setup in it and said it was quick but i am sure it could handle a Neu/MMM setup. especially with RCMonsters extended chassis setup.
