Ongoing problem with Hybrid output shafts...
Ongoing problem with Hybrid output shafts... - 11.01.2008, 07:38 PM
What to do 3 gone!
Setup is G3R CF 6S 123 Neu 1515 2.5DF 24/66....
Difficult to get a photo of the last one head on but it is twisted too...
11.01.2008, 08:52 PM
Ouch.
11.01.2008, 09:13 PM
Did you contact Mike about this yet?
11.01.2008, 09:36 PM
I spoke to mike after number 1 went down and showed Jamie and Mike the broken one at the bash...
I took the diff apart last night to replace the sheared one with my last spare but the second one is twisted to badly it isn't worth rebuilding the diff.
I have emailed mike tonight and sent him the pics...
TruckBasher
TruckBasher's Avatar
11.01.2008, 09:41 PM
Sad to hear that....
I have them too but haven't tested yet..
E-Slayer direct drive to diff
JThiessen
JThiessen's Avatar
11.01.2008, 09:46 PM
In cases like this, one tends to focus on the broken pieces as the "source" of the problem. However, maybe the real issue lies somewhere else in your drivetrain. Is it possible one of your shafts is binding up in a certain suspension position? If so, I would think your slipper would give before putting out enough power to shear these. One yes, three - no way. Just thinking out loud here...
I guess it comes down to one of two things. Either a string of defective parts, or you have something occuring that creates great opposing forces at that spot.
Has it been in the same spot every time? Have you noticed when it occurs?
11.01.2008, 09:51 PM
When it does backflips...
The drive train is clear it is just the rear diffs take all the punishment... The centre is running the beefy gorillamax dog bones... This part is basically the weak link in the chain... I guess I will need some more slipper action... But thats a fine line from just melting the slipper...
I guess I need the slipperential mike in G-REVO format :)
JThiessen
JThiessen's Avatar
11.01.2008, 11:04 PM
I still think its a material issue. You just happen to be the owner of the entire 1% of the bad parts.....
George16
Supermaxx
George16's Avatar
11.01.2008, 11:41 PM
I tend to agree with the material issue. I'm not sure if these are the same diff outputs traxxas made and Mike just cut the threaded portion off. If it is, then something else is going on in your setup because the traxxas ones are made of hardened steel. If not, ask Mike what material he used in making them.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
TexasSP
Something, anything, nothing
TexasSP's Avatar
11.01.2008, 11:56 PM
This could very well be an issue with the hardening process itself. It could have gotten too hot, not hot enough, cooled down too quickly, and so on. I remember Mike had some bad pinions a while back as well. Although I am not casting any blame on Mike himself for this just saying that it happens.
I have had guys screw up the hardening process for me on many occasions so it is very feasible.
www.cubicle101.com
crazyjr
crazyjr's Avatar
11.13.2008, 01:23 AM
I am running the V.1 diff conversion with buggy diffs (hot bodies) gorilla converted Emaxx tranny with steel center driveshafts, I also run the 1515/2.5d on 5s with both an MGM 16018 and a quark 125 and the only thing i ever broke was the input shaft (on 5s) and a 4 yr old front wheel shaft (stock) on a 6s run. I wish i could tell you what is going on, I'm impressed by the power you seem to have
pasan
I <3 RC
pasan's Avatar
11.17.2008, 05:53 AM
This is interesting, and makes me scratch my head a little, I mean if a 2.5D which is already a higher Kv motor, running on taller gearing, can break shafts like that, the stockers seem like a much better option. I have yet to twist a stock shaft, and I do beat my e-revo quite a bit.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
11.17.2008, 06:49 AM
pasan - I thought you ran a 2100kv motor on 6s geared 20/68 (about 50mph without tire ballooning).
I'm using a 1650kv motor which is geared for under 40mph - stands to reason my setup has more torque unless you are running a 1521/1527.
pasan
I <3 RC
pasan's Avatar
11.17.2008, 07:05 AM
My bad, I was thinking of a 1.5D for some reason, which is 2700kv. 1650kv is a lot more like it, and obviously a torque monster on 6S of any kind of lithium batteries. And the stock talons do balloon, and came apart in places along the rim, but they've been behaving since I re-glued them. But I digress, you would think these after market shafts would be stronger than the stockers. The rears on mine "creak" a little when rolling forward slowly ( for the longest time I thought it was the bearings ) but a little bit of WD-40 on the u-joints did the trick.
AX10 RTR - Stock :D
11.17.2008, 10:30 AM
The issue is enhanced I think as I'm running cvd's rather than plastic shafts.
The plastic shafts flex with the load to provide some flex - with the cvds that load is placed on the output shaft. I've chopped down some revo shafts to get me going.
Hopefully the slipperential will be out soon for the G3R.
