Medusa motor discolored by motor spray??
GYG
Medusa motor discolored by motor spray?? - 11.03.2008, 11:29 AM
So my V2 36-60 2000kv motor needed a quick blast of motor spray...some of the spray got on the outside of the can, and basically "tarnished" the blue anodizing...what the?
Anyone else have this issue? I've never had anodizing get hazed by motor spray like this before.
bl-is-future
bl-is-future's Avatar
11.03.2008, 11:33 AM
yep any hard degrease will strip the anodize right off. Dont use oven cleaner either that stuff is real potent to anodize.
GYG
11.03.2008, 11:38 AM
I don't think motor spray specifically sold to clean r/c motors should remove anodizing though...I've used this same spray to clean shock bodies, brushed motors, even my 1515 1.5d, and none of them have had this problem. I thought maybe the Medusas anodizng wasn't quite as "permanent"...
bl-is-future
11.03.2008, 11:49 AM
could be but i used motor spray on shocks before and the shock caps all got de anodized. The motor spray is a degreaser just lighter.
GYG
11.03.2008, 11:52 AM
Hmmm...wonder how you're supposed to clean the motor without getting at least SOME spray on the can...even if you're careful spraying the inside of the motor, shaking/blowing it out could get some on the can.
rchippie
rchippie's Avatar
11.03.2008, 12:47 PM
I use Denatured alcohol in a spray bottle if i dont have any motor cleaner . I've had good luck eith it .
REAL MEN RUN BRUSHLESS
bustitup
11.03.2008, 04:14 PM
why you guys trying to clean them....there not supposed to be clean...get in some nice deep mud and solve all these woes
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.03.2008, 06:40 PM
What motor spray are you using?
Area 52 Ranch Raceway
T.R.C.R.
