I can see the v2, v3 case difference, is the case change needed and will castle send you one or do they need to change it? Also I ran the v2 I have with the 1.20 programing and it ran well. at around 70 the fan comes on and off as needed. Very smooth and the truck had much more power then with the mm. I still need to run my v3 to see if it is ok. But again is the case change needed???
