12.15.2008, 03:35 PM
Your charge settings should be for 4s, or 14.8v, 5000mah or 5 amp charge rate. Plug the balance lead into the charger's port and the main lead into the output, and you should be good to go. I have not used that specific charger, but you should read the instructions thouroughly a few times to familiarize yourself with it.
