bustitup
12.18.2008, 05:39 PM
I just called them and they need a speaker with a removeable back plate or magnet assembly. I told them what I had and he said probably not. He then said to "slide by" the shop and he can take a look anyway, but I said it might be a tad difficult since I'm in Iowa and he's in Florida.
I'll look around locally, but I did some searching when I moved here and there was no luck then. I figured I'd just hold onto it for now, but it seems that it needs to be retired. Would make a really nice fridge magnet. Poo.
yes you have to remove the backet to ne able to glue the flat surround of the voice coil after it gets perfectly centered...then you screw the basket back down and squeez it together...I used do a little voice coil and paper replacement myself when I was in a pinch...its not that hard..you just have to be carefull
what your baskets dont come off?
