its me
There is no help for me... I'm addicted to R/C
its me's Avatar
01.06.2009, 03:11 AM
man that thing looks awesome. Are you able to run tall gearing? Take advantage of that extra torque!
Hahaha funny you said that, the gearing right now should be about 75MPH but im diffing out really hardcore.. I got 7K in the center :)
I was just bliping the throttle, thinking about running 22t pinions.
rccna.com
01.06.2009, 10:31 AM
Thicken up that center! Get the thickest you can get, a "locker" lube if you can. Oh, and more video
SnoopMaxx
SnoopMaxx's Avatar
01.06.2009, 05:48 PM
Awesome.. I love when he says "That was coooaall "
Morten SnoopMaxx
Never to old to play
c",)
Emaxx_Quebec
Emaxx_Quebec's Avatar
02.03.2009, 11:17 AM
What is the best to use to be closest to stock maxx diff
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
What the gear ratio of those diffs?
Thanks
02.03.2009, 12:08 PM
  1. Raminator
  2. Aftershock
  3. LST
  4. LST2
  5. Mayhem
Thanks
1st 4 you listed are all the same, 13/43 ratio. Not sure about the mayhem.
Emaxx_Quebec
02.03.2009, 12:13 PM
Thanks
So the only diference is the case. ( plastic vs silver alu vs blue alu)
Emaxx_Quebec
02.08.2009, 01:01 PM
question about the lst 2 diff convertion
do my traxxas driveshaft and center cvd can be use whit this convertion
a got a 3905 maxx
You'll need to purchase the adapters mike sells, here
. those will go in place of the normal outputs for the left and right. so if you replace both diffs you'll need 4 of those units.
So Ok for the 4 corners.
BUT for the center??
I use
Can I bore ( drill) them out to 8mm.
Or do I need something else like 2 of
If so, how do i connect them to the CVD.
Thanks.
