If you keep the 32p gears, yes. What is the minimum distance between the motor shaft and the input shaft? If you can get that measurement you can use BrianG's gear diameter calc to figure out what Mod1 gears you can fit. You could use a smaller pinion with a Jato spur if you wanted, but you'll get more speed and tougher gears with Mod1.
