Tobbe
01.25.2009, 03:17 PM
Oh I see. That's a shame about the motor mount. I think I'll go for the RCM mount then. I'm planning on using a Neu or a CC Monster combo and I don't want to realize that the shaft is too short for the motor mount
FG101C
01.25.2009, 08:29 PM
A freind is using the Castle motor, shaft is long enough. If your real good you could pull the front face plate off and retap the holes to 4mm, then it would be ok. Then just to find the right gearing since your a little bit limited on the spur size.
