alangsam
01.31.2009, 07:42 PM
cool. thanks. next question, have pivot balls popping out on the front end from time to time. Whats a good way to harden these?
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
02.07.2009, 11:05 PM
Does your ERevo have the new Traxxas carriers introduced on the Platinum Revo? Part # TRA5334R. They're the ones with the metal ring around the pillow ball hole. They also use a bigger outer bearing. If not then get them, they are cheap and work great. If the 5334R are the ones you're running and managed to pop pillow balls through them then you might need to go heavy duty with RD Racing carriers. The suggested RPM carriers are fine if you don't have the Slayden steering mod done. With the Slayden mod, the RPMs pop pillow balls too. I use the Traxxas 5334R and I have the Slayden mod done and I still have to pop a pillow ball after a full season of racing and bashing. Tekno also came out with their own carriers that have aluminum reinforcements around the pillow ball hole. I never tried those.
No brain, no headaches.
what is the slayden steering mod?
alangsam
what is the slayden steering mod? - 02.08.2009, 06:52 AM
What is the slayden steering mod? I have the e-revo and installed the part that gives you extra steering but i still dont have as much steering turning to the left as i would like.?
mistercrash
Guelph, Canada, eh!
02.08.2009, 10:52 AM
The Steve Slayden's steering mod
It's simply a few little modifications you can do to get the maximum steering throw from your Revo. But it does come at the expense of pillow balls popping out if you don't have some kind of reinforced carriers like the 5334R from Traxxas or the expensive RD Racing ones.
madmaxx
REVO madman!
madmaxx's Avatar
link to slayden mod's http://www.traxxas.com/support/kb_se...472&artlang=en
look's like mistercrash beat me to it!
you can also mod the stock carrier's with a piece of copper tubing IIRC
are your toe link's set-up equally?
REVO picco .26 << too many mod's to list
TT st-1 OS .30 << stock
CEN matrix FRE OS .21rg
http://ca.geocities.com/jleblao/
