02.09.2009, 03:32 PM
Yes, you can drill out the stock part to 8mm to fit the diff shaft- seen it done a couple times. You cant use Mikes part with cvds, you'd have to use dogbones with different drive cups that he sells (8mm bore), or possible drill out the cvd to 8mm, but that might weaken it too much.
