stum
03.24.2009, 05:53 AM
I don't want the CC/Neu because it's a 2200kv motor! I'm running 5s and I don't want to gear down that much. Lower kv higher Voltage geared for the same speed is a more efficient setup. Also a small pinion and large spur that would be needed for the 2200kv on 5s isn't as efficient either. The closer the two gears are to the same size the less resistance there will be between the gears. My 1515 2.5D is 1650kv and I'm very happy with it, a little less power wouldn't be bad. A 1600kv Medusa is the closest I can get to this without shelling out another $260. I already have a 36-50-4800 in my crt.5 and the motor is awesome, I expect larger motors will be of the same quality.
Well I agree about the 5s, just make sure you can run it racing... many tracks won't allow over 4s hardshell. If it's open though and doesn't matter and you want to stick w/ 5s price wise you can't find a better option than the medusa 70 or 80mm. I would get the 70mm if you only want 40mph, if you want 50+ I'd say get the 80mm can.
To your point also.. I have a Neu 2.5d on 5s in my Losi 8ight-t conversion and it's perfect on the track :) I have the Medusa 36-60-2000 in my 8ight buggy and that too is a perfect home for it, the motor again wasn't quite enough for the truggy or erevo but is sweet on the buggy.
Good luck.
