crazyjr
crazyjr's Avatar
05.16.2009, 04:12 AM
Originally Posted by Chadworkz View Post
Just keep in mind that the Mini CRT and Mini Hyper are 1/12 scale and can easily be made into 1/10 scale via commonly available parts (they are already about the size of most 1/10 4wd buggies), but the Mini Revo is 1/16 scale, which is much smaller, and can not be made into 1/10 scale...well, you could, but it would be very impractical and very expensive, requiring a lot of custom parts...and it would not hold up to the power of anything larger than a brushless 28mm or 370-size motor.
I'm not sure the mini e-revo will be that fragile, here is a quote from Tim Roberts on the mini E revo from revo racers
From Tim Roberts, taken from revo racers. com
The diffs are all metal- bulletproof. The driveshafts are almost the same size as Jato- don't worry about them either. The tranny is a combination of metal and plastic gears- indestructible. Basicly the driveline is designed to handle 1/10 scale loads but fit in a mini. Good luck breaking it.
Personally, I might have to try my lehner 1200xl/quark 80 on 5s combo in it. All i'd need is a reversed adapter to run a 540 on a 370/380 motor
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.16.2009, 05:23 AM
Very cool!!!
-Chad
PM ME IF YOU HAVE THE BELOW:
