05.16.2009, 12:18 AM
If you go the CRT.5 or Hyper STe route then get a Medusa 36-50 3300kv for 3S. I'm kinda in the same dilemma as you but it's between the Hyper STe and the CRT.5...
UE Supermaxx Addict!
05.16.2009, 02:05 AM
Just keep in mind that the Mini CRT and Mini Hyper are 1/12 scale and can easily be made into 1/10 scale via commonly available parts (they are already about the size of most 1/10 4wd buggies), but the Mini Revo is 1/16 scale, which is much smaller, and can not be made into 1/10 scale...well, you could, but it would be very impractical and very expensive, requiring a lot of custom parts...and it would not hold up to the power of anything larger than a brushless 28mm or 370-size motor.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
05.16.2009, 04:12 AM
I'm not sure the mini e-revo will be that fragile, here is a quote from Tim Roberts on the mini E revo from revo racers
From Tim Roberts, taken from revo racers. com
The diffs are all metal- bulletproof. The driveshafts are almost the same size as Jato- don't worry about them either. The tranny is a combination of metal and plastic gears- indestructible. Basicly the driveline is designed to handle 1/10 scale loads but fit in a mini. Good luck breaking it.
Personally, I might have to try my lehner 1200xl/quark 80 on 5s combo in it. All i'd need is a reversed adapter to run a 540 on a 370/380 motor
BMW M Power!
05.16.2009, 04:30 AM
I currently have a CRT.5 with my own chassis (actually it's the chassis that Mike's chassis are based off of), so basically you could say I have a V1.
Anyway, I really like the little CRT. It handles great, is very durable, and is quite a blast to drive. I like how it isn't so small that everything upsets it, but rather I've driven it on 1/8 scale tracks and it took the rough sections fine.
I have one of the 1/16 Revo's on order, and from what I heard, they are just a shrunken full size E-Revo. If there is any truth to that statement, they should be durable and handle quite well.
I don't think you could go wrong with either, so I would choose based on what you already have in your stable.
Since you already have a Hyper 7 and Rustler, you have two vehicles pretty similar to the CRT.5, so I would say get the 1/16 Revo. This way, you'll also have a wet-weather capable vehicle.
05.16.2009, 05:23 AM
Very cool!!!
-Chad
05.16.2009, 06:25 AM
is the 1/16 revo fully waterproof even the brushless system? and do you reckon it can take 4s lipo (the esc and motor i mean)
05.16.2009, 06:54 AM
Traxxas claims they are water proof. I wouldn't run it on 4s, the ESC may handle it but not reliably. The motor is made by Feigao, so 60,000 RPM is a very bad idea. Keep it to 3s or get a different power system.
RC-Monster Spudgunner
05.16.2009, 08:31 AM
There are bound to be bugs with the e-revo. Weather it is diffs or servos I'm sure something will come up. I'd get one of the truggies if you don't want to deal with that. I've got a crt .5 and I'm more then happy with it.
A 16yr old with a combover
05.16.2009, 11:41 AM
idk about the waterproofness, but I never planned to use the vxl system either. I was just planning on a MM and separate motor. does anybody out there have the mini STe? havent heard much about that. It looks similar to the crt.5, but has a longer wheelbase than the jammin extended chassis
05.16.2009, 03:45 PM
Since the CRT.5 is made by Jammin, and the Mini HyperST & STe is made by Ofna, and Ofna owns Jammin, I wonder if they are similar platforms? Anyone know anything about that?
-Chad
05.17.2009, 12:29 AM
just looking at them on towerhobbies, they do look kinda similar, and from reading other forums the only found differences was the longer wheelbase on the mini STe and a different wing.
05.17.2009, 12:49 AM
And the PBS suspension...
05.17.2009, 03:48 AM
Is the STe's chassis any longer than Mike's CRT.5 chassis? if not, or if it is the same length, then Mike's RCM CRT.5 chassis and wide-track conversions should work very well on the STe!
-Chad
05.17.2009, 06:20 AM
CRT is made by Hong Nor, Hyper ST is made by Hobao. Different companies, but both are badged as Ofna in some parts of the world. The ones I have seen for sale in Australia are sold as Hong Nor and Hobao, not Ofna, so I doubt that they are designed to be very similar.
