did i make a mistake
stampy
stampy's Avatar
did i make a mistake - 12.25.2005, 07:00 PM
buy selling my 23mm adapters with my wheels and tires that i sold? am i going to be stripping the hexes out of wheels with standerd 14mm alum hexes?
rchippie
rchippie's Avatar
12.25.2005, 07:03 PM
not nessicerally, just make sure your locknuts are tight. You also should replace them every so often because the nylon in the nut wears out. If you have room on the axle double nut if you can. This helps prevent the nut from backing off.
REAL MEN RUN BRUSHLESS
Basketti
12.25.2005, 07:04 PM
what motor do you have?
stampy
stampy's Avatar
12.25.2005, 07:06 PM
nothing yet but i plan on going 8xl or 9xl. if i some how win the lottery ill probbly throu in a 2240 :p
Nick
COOKIES!
Nick's Avatar
12.25.2005, 07:27 PM
I doubt 14mm will strip anything. As long as they are metal and you have good wheels. Nothing to worry about.
Plastic however, you can wave good buy if you have plastic hexs.
~ Nick.
stampy
stampy's Avatar
12.25.2005, 07:31 PM
cool guys tnks
