TexasSP
Something, anything, nothing
TexasSP's Avatar
06.03.2009, 04:20 PM
Are you sure? I got it from a guy on rctech that had no pics about 1 yr ago...
Yup, that was it. I talked to the guy about it but you already had dibs. I got interested in them after bdebde posted his up. It's no biggy, I was just jacking with you.
www.cubicle101.com
06.03.2009, 04:58 PM
Originally Posted by drkdgglr View Post
Are you sure you weighed them correctly? It just seems very light for a 40series wheel/tire combo. I believe you weighed the 40 series wabash/crimefighter combo @230grams? The stock weigt is 330grams. So I could save 400grams on rotating mass vs the stock setup?
I will weight them again, and weigh all 4 to make sure that it is not a fluke. The 0 offset is not the same as the losi 420 wheels. They look closer to a 1/2 offset. I will be buying some more proline wheels in half offset and we will see how they do. The O offset look good with the boltons on a savage that I have, not too wide.
You have a good memory... I can barely remember my own name sometimes...
riverat1540
riverat1540's Avatar
10.06.2009, 12:58 PM
just wondering how the mmm is holding up in the muggy with the 1521, the 2200kv was not a good fit which i knew but pushed it around great, but the speed control could not handle it, im waiting on my replacement so i can try the medusa 36-80-2000kv which unsullied spy is having goot results with just a bit on the hot side due to gearing. also what does your truck weigh completed, im at 13.5lbs with the rollcage
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
